Wiper Motor connection - Team Camaro Tech
post #1 of 14 (permalink) Old Oct 12th, 09, 08:19 AM Thread Starter
I hav a 1967 Camaro with a four terminal connecter on it. Apparently whoever put in the first motor did not put the wires back into the connector properly. The motor continues to blow fuses. Can somebody help me out withthe proper way to connect the wires?
Thank you
MY67REDSS is offline
post #2 of 14 (permalink) Old Oct 14th, 09, 01:27 PM Thread Starter
Re: Wiper Motor connection
UPDATE:: When looking at the firewall and going left to right the
#1 connector is Black (GND)
#2 = ???
#3 &#4 are electrically the same point = ???
I have YELLOW = 12v straight from fuse block
Light Blue = ??? to motor from switch
Dark Blue = ??? to motor from switch
Any ideas on which wire connects to which connection on the motor?
Thank you
post #3 of 14 (permalink) Old Oct 14th, 09, 06:02 PM
Hi Deanne.
I took a photo of mine for you. This should help.
Melrose RS is offline
post #4 of 14 (permalink) Old Oct 15th, 09, 07:58 AM Thread Starter
Thank you for the picture, but my motor is just a bit different (see below) The two terminals on the right are connected together. I have a BLACK, YELLOW, LIGHT BLUE & DARK BLUE wire.
Thanks again
post #5 of 14 (permalink) Old Oct 15th, 09, 08:08 AM
Not sure, could that be a 68 motor? Electronically it may be the same.
post #6 of 14 (permalink) Old Oct 15th, 09, 09:28 AM Thread Starter
According to RICK's 1st Generation Camaro the four terminal is a 1967 and the three terminal is a 1968 - 1969.
post #7 of 14 (permalink) Old Oct 15th, 09, 10:00 AM
Rick's has a few things inaccurate in their catalogs. I can think of a few examples. Do you have the AIM(67 assembly manual)? I can check it later at home to see if it mentions anything about different wiper motors.
post #8 of 14 (permalink) Old Oct 15th, 09, 10:25 AM Thread Starter
No I do not.
post #9 of 14 (permalink) Old Oct 15th, 09, 10:50 AM
foreverlookin's Avatar
67 has a round opening and 68/69 is an oval and will not fit on a 67. This is a 68 opening for a the wiper motor. Also found a 67 engine bay that may help you.
foreverlookin is offline
post #10 of 14 (permalink) Old Oct 15th, 09, 11:17 AM Thread Starter
I have the round opening. I do not have the washer pump with mine. I only have the wiper motor. Is the washer pump required for proper operation?
post #11 of 14 (permalink) Old Oct 15th, 09, 11:21 AM
Only for squirting. The wipers should work without it. I would just disregard that last connector on the right since it is continuous with the one next to it. Cover it with heat shrink tubing.
post #12 of 14 (permalink) Old Oct 15th, 09, 11:32 AM Thread Starter
So BLK on the far left. What wire is center and right?
Light Blue or Dark blue?
Yellow?
Thank you
post #13 of 14 (permalink) Old Oct 15th, 09, 12:57 PM
Light blue is center. Yellow is right. Dark blue connects to the pump as in my photo.
post #14 of 14 (permalink) Old Oct 15th, 09, 03:17 PM Thread Starter
That did the trick! Thank you for your help.
