Brake light switch - Team Camaro Tech
post #1 of 4 (permalink) Old Oct 13th, 09, 03:33 PM Thread Starter
Patrick
Brake light switch
I just installed a new wiring harness in a street rod project, and the steering column is from a mid 1970's Chevy. It seems that the brake light switch is working backwards. When the brakes are pushed down the brake lights go off, when the pedle comes back up all the way, the lights come on. There is power to one side of the switch. Has anyone ever heard of this. Thanks.
PDW HOTRODS is offline
post #2 of 4 (permalink) Old Oct 13th, 09, 04:50 PM
Jeff
yellow69RS's Avatar
Re: Brake light switch
Does that switch have four spade terminals on it? If so two are for cruise control and are normally closed , the other two are normally open.
Jeff
yellow69RS is offline
post #3 of 4 (permalink) Old Oct 13th, 09, 08:32 PM Thread Starter
Patrick
It has 2 terminals. The column does have cruise, but I think it has its own 2 wire plug.
post #4 of 4 (permalink) Old Oct 14th, 09, 10:02 AM
Jeff
yellow69RS's Avatar
If the cruise has a separate switch I'd be somewhat surprised but not entirely impossible. It sounds like this is as simple as buying the correct normally open switch.
Jeff
