hideaway headlites from scratch - Team Camaro Tech
post #1 of 6 (permalink) Old Oct 17th, 09, 11:20 AM Thread Starter
from where do you get power to the breaker on the relay bracket, is there a particular place to get it or can you get power from anywhere??
railer3 is offline
post #2 of 6 (permalink) Old Oct 17th, 09, 04:22 PM
Re: hideaway headlites from scratch
If you are talking about a 67 RS, mine goes from the relay bracket assembly (under the driver's front fender) & connects to the headlight switch under the dash. That way, when you pull the light switch to turn the lights on, the RS doors open.
327!275hp!Convt! is offline
post #3 of 6 (permalink) Old Oct 17th, 09, 04:50 PM Thread Starter
to what color wire off the lght swich is it???
railer3 is offline
post #4 of 6 (permalink) Old Oct 17th, 09, 05:00 PM Thread Starter
yes, I currently have my pwr wire hooked up to the horn relay it was the closest, and amazingly it works fine, just want to put it in the right place....
railer3 is offline
post #5 of 6 (permalink) Old Oct 17th, 09, 07:32 PM
Roger
rogerh's Avatar
Check out this link.
Roger
http://www.pozziracing.com/Media/67rswire.jpg
rogerh is offline
post #6 of 6 (permalink) Old Oct 18th, 09, 09:53 AM
The main power feed is from the horn relay to circuit breaker on the rellay board.
Marktat is offline
