brake light switch...HELP!!! - Team Camaro Tech
post #1 of 2 (permalink) Old Oct 17th, 09, 08:30 PM Thread Starter
frank
just started the wiring on my 67 camaro...i got an aftermarket wiring harness from EZ WIRING...having trouble wiring up my brake light switch...i have one wire coming right off the fuse box that is power for the brake light switch...and i have another wire that says "brake light switch" where does the 2nd wire go to???
fjas67 is offline
post #2 of 2 (permalink) Old Oct 17th, 09, 09:06 PM
Rick
Re: brake light switch...HELP!!!
The one off of the fuse box goes to the Ebrake switch
The other one goes to the switch on the brake pedal
Rick
68 project...reassembly starting: (383, AFR 195, Air Gap, Comp Cam XR276HR, 1.6 CC Gold rollers, Holley 750, 4/09) (TKO 600 conversion from T350 4/09) (floor pan restored 6/09). (12 bolt 3.73, Wilwood disc, Hotchkis TVS 7/09), Dougs 368 with Big Dog mufflers (9/09), 383 fired up 9/30/09, Candy Apple Red 2012 with white RallyBee stripe
dukemd66 is offline
