1196 Camaro Ignition Key Issue - Team Camaro Tech
post #1 of 5 (permalink) Old Oct 20th, 09, 06:24 AM Thread Starter
Well I have a new issue with my camaro. It had been sitting a couple of months with no battery. Long story, but it was in hiding. You put in the ignition key and turn it and nothing except the security light coming on. I did some reading on the internet and called the dealer and the conclusion is one of 2 things. Either the key has gone bad or the tumblers have. I read on the net where there have been issues with the ignitions going bad on these quite often. Unfortunately this is a second hand car and I only have one ignition key so I cannot try the spare.
I also read where leaving the key in for 10 minutes and trying again will work. But nothing.
The delaership wants $140 for a new ignition and keys. Then labor takes it up over $400. Wow... I know on older cars you could turn the ignition switch to a certain position and pull it out and replace it.
My questions are-
Has anyone ran in to this before and have a trick to getting it started?
And can someone point me in the direction of how to remove the ignition and replace it myself? Surely it can't be that big of a job, can it?
Thanks for any feedback.
RSFish1 is offline
post #2 of 5 (permalink) Old Oct 20th, 09, 09:53 AM
Guess
HwyStarJoe's Avatar
Re: 1196 Camaro Ignition Key Issue
What year is it?
HwyStarJoe is offline
post #3 of 5 (permalink) Old Oct 20th, 09, 10:16 AM
James
Originally Posted by HwyStarJoe View Post
What year is it?
It's probably a 1996 with the troublesome PASS key system.
You can either pay up to fix it right or bypass it.
Here is one of many ways to do that.
http://vats.likeabigdog.com/
68 Ragtop is offline
post #4 of 5 (permalink) Old Oct 20th, 09, 10:42 AM Thread Starter
Sorry. It is a 1996. I will check out that link. Thanks!
RSFish1 is offline
post #5 of 5 (permalink) Old Oct 20th, 09, 05:24 PM
Jeff
yellow69RS's Avatar
Try a different dealer. I locked the radio in my truck, the search on the net showed charges from free to hundreds of dollar to fix. It took me ten minutes and a phone call.
With the original key available should make this alot simpler for the dealer ( or locksmith) the actual parts I think you can change. If you get a new cylinder with key Team Camaro can tell you how to change it.
Jeff
yellow69RS is offline
