67 rs headlight relay clicking - Team Camaro Tech
post #1 of 1 (permalink) Old Oct 23rd, 09, 09:17 AM Thread Starter
i bought all new rs wiring harness front to back .i have all the headlights opening & closing great,but when i try & start car or turn the ignition switch to on position one of the headlight relays click like the points that's inside of relay are opening & closing rapidly.is this normal,also with the ignition switch on I'm reading 12 volts if i use a voltmeter & put the red lead on the motor & the black lead on ground it will actually shock you if you touch motor with key on.i know this cant be right.i have the harnesses all plugged in where they go any ideals what i have done wrong.could this be a ground problem.thanks to all who reply
anthony hisle is offline
