dark dash/turn signals - Team Camaro Tech
post #1 of 6 (permalink) Old Oct 25th, 09, 09:17 AM Thread Starter
Well,this one has me stumped!Maybe someone has had this happen to them on they're 69 camaro
A few weeks back my turn signals stopped working,but the four way flashers work.I tested the turn signal flasher and it is working properly.
A day or two later my dash lites all go dark.I figure it has to be the lite switch right?Nope,i replace the switch and still the dash is dark.
All the headlights and running lites are working just fine.
Any ideas??
DRBRICK
69 SS350 4spd.
69 RS350 (project)
68 Cuda(finally done)
drbrick is offline
post #2 of 6 (permalink) Old Oct 25th, 09, 10:57 AM
Re: dark dash/turn signals
Check your grounds. take a wire and ground the cluster, see if that works.
Aaron67 is offline
post #3 of 6 (permalink) Old Oct 25th, 09, 09:27 PM
also check the small glass fuse in the fuse block to see if it is blown. I had the light on the hvac controls come loose (with no bulb) and it arc'd and blew the fuse. taped the end, replaced the fuse and the lights came back.
but, originally my cluster wasn't grounded at all so make sure yours is on there and not loose/missing!
brownnote is offline
post #4 of 6 (permalink) Old Oct 26th, 09, 10:06 AM Thread Starter
Thanks guys-i will try those ideas out and see what happens.
DRBRICK
69 SS350 4spd.
69 RS350 (project)
drbrick is offline
post #5 of 6 (permalink) Old Oct 28th, 09, 07:53 AM Thread Starter
Well it wasnt a ground problem after all.I started poking around the fuse block and found that some of the fuse holder contacts were corroded!Even though my test lite was showing power on both sides of the fuses,i was not getting contact on one side of the holder.Also, on the back side of the fuse block some of the spade connectors were corroded and not making good contact.Alittle bit of sand paper to clean all contacts,and im back in buisness...One thing that does bother me though-the headlight switch will not dim the dash lites.I try to dim them and they just go off.I can live with that.
Thanks for all the help.
DRBRICK
69 SS350 4spd.
69 RS350 (project)
drbrick is offline
post #6 of 6 (permalink) Old Oct 28th, 09, 12:40 PM
Guess
HwyStarJoe's Avatar
New switch.
I used electrical contact lube (dielectric grease) on all my sockets and the fuse block. The fuse block still had a lot of the factory molasses goop in it.
HwyStarJoe is offline
