Having problems with my Starter - Team Camaro Tech
post #1 of 11 (permalink) Old Oct 27th, 09, 02:47 PM Thread Starter
This is not for my Camaro, its for a 95 Chevy G20 van.
I am truly stumped with this. My origional Starter died (after 5 years of service). I tried going cheap by replacing it with two junk yard starters, and neither of them were any good.
I finally gathered up the good sense to go on and buy a BRAND NEW one for $145. Thing ran fine for abut a week. Now I'm back to the same old problem, only I have to get out and tap on the starter with a crowbar to get the blasted thing to work.
Sometimes it starts right up, and others I have to tap on it.
I checked the battery and its holding a full charge
I shouldn't have to be going through this with a Brand New starter right out of the Box.
Any recommendations will truly be appreciated
When you buy an American car, you provide work for a man and his family for three months. -Jay Leno
garfield is offline
post #2 of 11 (permalink) Old Oct 27th, 09, 04:25 PM
Skip
Skeeter55's Avatar
Re: Having problems with my Starter
The positive wire from the battery to the starter may be bad and burning up your starters including a bad connection or wire to the solenoid.
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #3 of 11 (permalink) Old Oct 27th, 09, 05:27 PM
Who's brand new starter?
I agree with cleaning and tightening all the connection, maybe replace the pos lead to the starter just because, but... If you want a good starter, go to GM and buy a delco. If that's what you have, well back to the wires.
post #4 of 11 (permalink) Old Oct 27th, 09, 06:28 PM
Alan
You could very well have a "new" starter that is bad out of the box.
If you still have your original starter, you could take to a starter shop and have it rebuilt, they usually use much better components than the bulk rebuilders. Look for a shop that has been around for a long time.
alan
alanrw is offline
post #5 of 11 (permalink) Old Oct 27th, 09, 06:44 PM Thread Starter
I'll try starting with the wires first and coem back with what I find.
garfield is offline
post #6 of 11 (permalink) Old Oct 27th, 09, 07:19 PM
alan
X2
1969 Z28
1969 Firebird 400
My new project for 2010 DONE/ Sold.
2002 Camaro SS LE/SLP
67 Nova SS 327, M20, 3.73
nashcar is offline
post #7 of 11 (permalink) Old Oct 28th, 09, 02:46 AM
All my starters and alts go to a shop now for rebuilding. I bought a reman starter and it was bad. I bought a reman alt and it had a dry bearing and used brushes. But both had shiny cases and a new box.
Sauron67MM is offline
post #8 of 11 (permalink) Old Oct 28th, 09, 03:53 PM
new just means different not necessarilly good.
NEVER argue with a stupid person. They bring you down to their level, and then beat you with experience.
bighaas79 is offline
post #9 of 11 (permalink) Old Oct 28th, 09, 09:49 PM Thread Starter
Now I have to find a reliable place that rebuilds starters
garfield is offline
post #10 of 11 (permalink) Old Oct 28th, 09, 10:03 PM
Alan
Get a recommendation here and UPS it to the shop.
alan
alanrw is offline
post #11 of 11 (permalink) Old Oct 29th, 09, 12:18 PM
Steps
They are not hard to rebuild...basically new bushes/bearings and contacts if dont have a lath, fine emery and a lrather boot stap.
And ohm meter to check diodes
And if cant access a growler for the starte armeture, get it hot to touch in the oven and check for dry joints.
Steptoe is offline
