Lincoln Mark VIII fan wiring question - Team Camaro Tech
post #1 of 4 (permalink) Old Oct 28th, 09, 08:32 PM Thread Starter
Joe
Question Lincoln Mark VIII fan wiring question
I have a wiring question.
I have a Mark VIII fan on my 69. It's been installed for about 4 years now and works great.
My fan is a 3-wire fan. I have 2 75 amp relays connected to it. One from the thermostat control; the other from the AC clutch (fan comes on with the clutch). The pigtail has three wires. I am using the outer connections as the positive from each of the relays. I am using the center as the ground. This setup has been working fine. The fan runs only at high speed.
From reading posts here on the Mark VIII fan setup, it seems that the center wire is supposed to used for low speed fan.
Does anyone have a real wiring diagragm that describes this? My setup has worked fine for 4 years so I don't think I am hurting the fan by having it wired this way. I am curious how it should really be wired.
joe
Joe G
69 Coupe; ZZ430; TKO600; 3.55 posi; 13" Baer 4 wheel discs; 17" Billet Specialties wheels; Hotchkis/Koni rear; Ride Tech front; Classic AutoAir AC and power windows cuz I'm old and lazy!
Joe G is offline
post #2 of 4 (permalink) Old Oct 30th, 09, 09:43 AM
Carl
Re: Lincoln Mark VIII fan wiring question
Some of the MarkIII fans have the center terminal dummied. Pop the plastic inspection cover off of the motor near the plug to see if the center terminal is fuctional.
CarlC is offline
post #3 of 4 (permalink) Old Oct 30th, 09, 09:52 AM
JohnnyRotten
i have a few links saved at www.JollyRodder.com that i try to help folks with, this is one of them:
scroll for schematic & info Taurus Fan wiring
SHIFTY4 is offline
post #4 of 4 (permalink) Old Nov 4th, 09, 03:52 PM Thread Starter
Joe
Thanks guys
Joe G
Joe G is offline
