1968 camaro ignition switch color wire question - Team Camaro Tech
post #1 of 6 (permalink) Old Oct 29th, 09, 09:05 PM Thread Starter
does any know what colors are for what on the back of a 68 camaro ignition switch?
s4dustin is offline
post #2 of 6 (permalink) Old Oct 29th, 09, 09:33 PM
Re: 1968 camaro ignition switch color wire question
the purple on is for the starter solinoid. the brown is for ground. I believe
smokey1010 is offline
post #3 of 6 (permalink) Old Oct 29th, 09, 09:43 PM Thread Starter
what wire is the starter wire trigger?
s4dustin is offline
post #4 of 6 (permalink) Old Oct 29th, 09, 10:04 PM
Dale
purple
68 Dana 302, 68 rs 327 daily driver/family car, 71 rs, track car/ driver, 68 firebird 400, 70 formula 400, 73 type LT, 98 TA, 2 goofy kids and an incredible wife.
dale68z is online now
post #5 of 6 (permalink) Old Oct 29th, 09, 10:07 PM Thread Starter
Thanks Dale.
s4dustin is offline
post #6 of 6 (permalink) Old Oct 30th, 09, 10:02 AM
There are no grounds connected to the ignition switch. The door jamb switch wire (20 Black) may appear to be a ground, but only when the door is open.
From the AIM:
*12 PurPLe - Crank wire which connects through the neutral safety switch and eventually to the 'S' terminal of the starter solenoid
*12 Pink - IGN power supplies power to gauges, signal/bu circuits and ignition circuits
*12 BRowN + 24 Brown/White - Power to Wiper, Heather A/C, Radio circuits. The Brn/W is related to the GEN lamp circuit and most likely ensures the generator (alternator) remains excited even if the GEN lamp burns out.
*12 Red - Main power input from horn relay via firewall connector.
*20 DarkGreen - Associated with the temperature switch. I'm not sure exactly how that circuit is wired but presume it may be for a temp light bulb test feature when cranking.
*20 Black - Door jamb switch used for key in the ignition buzzer.
*20 Pink - To horn relay key in the ignition buzzer connection via the firewall connector.
dnult is offline
