Wacky Wipers! - Team Camaro Tech
post #1 of 7 (permalink) Old Oct 31st, 09, 04:28 PM Thread Starter
Gary
Wacky Wipers!
They only work when I push, and hold, the button in. Any thoughts?
Gary
Gar's67 is offline
post #2 of 7 (permalink) Old Oct 31st, 09, 06:29 PM
Re: Wacky Wipers!
Bad switch or poor ground I'd think. I believe when you turn on the wipers you are providing ground to the circuit through the switch...
Melrose RS is offline
post #3 of 7 (permalink) Old Oct 31st, 09, 08:38 PM Thread Starter
Gary
Re: Wacky Wipers!
What does the ground consist of? The dash area of my car was painted when the whole car was painted. I did not sand or remove any paint from this area. Thanks
Gary
Gar's67 is offline
post #4 of 7 (permalink) Old Oct 31st, 09, 10:02 PM
Nev
Re: Wacky Wipers!
When you fit the wiper switch there should be a circuit to ground from the body of the wiper switch
You may have to remove some paint (from somewhere you can't see it) so the switch can get a ground circuit.
Rgds,
Nev
Almost finished (?) 68 Camaro
383 stroker
T350
12 bolt Moser
nev68 is offline
post #5 of 7 (permalink) Old Nov 1st, 09, 07:24 AM
Re: Wacky Wipers!
I used a star washer behind the switch (from the back side of the instrument panel). The switch has to have a good ground to work properly.
68 Coupe, 350, M20 frame off restoration (a work in progress).
ironhorse78247 is offline
post #6 of 7 (permalink) Old Nov 1st, 09, 05:58 PM Thread Starter
Gary
Re: Wacky Wipers!
I tried the star washer and no luck. Help needed!! Same results
Gary
Gar's67 is offline
post #7 of 7 (permalink) Old Nov 2nd, 09, 06:18 AM
Re: Wacky Wipers!
I had this exact same issue and it was a bad wiper switch. I replaced it with one from firewheel classics (site sponsor) and it works perfectly now. It was one of the many electrical items that i have had to replace once I got my 68, but def. an easy fix.
brownnote is offline
