No spark - Team Camaro Tech
post #1 of 6 (permalink) Old Nov 1st, 09, 10:32 AM Thread Starter
No spark
I was trying to adjust the timing on a 63 327 v8 in my pickup. I let my hand off the distirbutor when it was running and it hopped up about and inch now my timing is out of wak. I retimed it to TDC and now i get no spark at all...
Any suggestions?
thanks cody
Cody udell is offline
post #2 of 6 (permalink) Old Nov 1st, 09, 10:34 AM Thread Starter
Re: No spark
Just to add my distributor is the old school vaccume advance
post #3 of 6 (permalink) Old Nov 2nd, 09, 09:31 AM
Russ
Re: No spark
Chances are you are 180 off on the timing, ie: pointing to #6 vs. #1. If you search there are some good posts on finding TDC on this forum. Then try static timing at ~5-8 btdc and see if she'll start.
Russ (RJ)
The Garlic Capital, Gilroy,CA
(sold June 15,2014) 1968 RS convertible that is not quite stock
rj68RS is offline
post #4 of 6 (permalink) Old Nov 4th, 09, 06:53 PM
Keith
Re: No spark
Either 180*, or when it "hopped" up about an inch on you, it slipped atooth, and will not now be right without "significant" adjustment to the cap...
I'd pull the distributor, rotate the motor to 12* BTDC and drop the dizzy back in...search for timing on here, and ther eare some really informative tips--helped me about a month or so ago!
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
keithl1967 is offline
post #5 of 6 (permalink) Old Nov 4th, 09, 07:54 PM
Re: No spark
And be sure to put the clamp back on there just loose enough to turn it. There is no way it should be able to pop out.
dnult is offline
post #6 of 6 (permalink) Old Nov 5th, 09, 03:07 AM
Re: No spark
Are points opening?
Good suggestions here.
