67RS Headlight door control arm assembly? - Team Camaro Tech
post #1 of 5 (permalink) Old Nov 2nd, 09, 06:45 AM Thread Starter
I must be missing some special washers or discs that mate the control arm to the headlight motor shaft.
The motor shaft is keyed, while the hole in the control arm is round so the motor shaft just spins in the hole when i put power to it to test. How exactly does the control arm engage the motor shafts so the doors will move? Is there some kind of keyed washer or fiber disk that grips the shaft?
Any closeup pics of the assembly would be a huge help....thanks!
________________________________
1967 RS 460 BB, TKO 600, 3.42 12 Bolt posi
mpaq is offline
post #2 of 5 (permalink) Old Nov 2nd, 09, 08:29 AM
Roger
rogerh's Avatar
Re: 67RS Headlight door control arm assembly?
Check out the links below.
Roger
http://www.classicindustries.com/con...roductYearId=0
http://www.classicindustries.com/camaro/C692.html
rogerh is online now
post #3 of 5 (permalink) Old Nov 2nd, 09, 08:48 AM Thread Starter
thanks very much Roger, i'll order those parts today.
So I understand the assembly then... assuming that the control arm is sandwiched between the two washers, is it the shouldered nut that applies pressure from the bottom so they dont slip? I gather the nut should not be really tight, just enough that the washers grip the shaft........but there should be no play or space at all right? otherwise the washers would simply turn with the shaft...
there is also this bushing kit listed at Ricks.....do i also need these?
Camaro Headlight Door Bushing Kit, Rally Sport (RS), 1967
Includes all headlamp assembly bushings, wave washers and four Mylar RS motor friction discs. 14 pieces.
mpaq is offline
post #4 of 5 (permalink) Old Nov 2nd, 09, 09:37 AM
Gary
TraxUnderground's Avatar
Check this out
http://www.retro-electro.net/diagram.html
Gary
67 RS Resto-Mod 468 5 spd TKO600 3.73 12 bolt (work in progress but finally on the road!)
73 Camaro project in a million pieces
TraxUnderground is offline
post #5 of 5 (permalink) Old Nov 2nd, 09, 10:15 AM Thread Starter
Perfect!!!
thanks
mpaq is offline
