Turn Key, starter won't engage - Team Camaro Tech
post #1 of 7 (permalink) Old Nov 3rd, 09, 10:08 AM Thread Starter
Gary
No click no nothing. I replaced the poitive cable from battery to starter, then replaced the starter & solenoid. What's the next logical step (not that I made logical steps to begin with) - thanks.
garyfbody77 is offline
post #2 of 7 (permalink) Old Nov 3rd, 09, 10:23 AM
Ken
Re: Turn Key, starter won't engage
Is the battery fully charged?
edit: Are the connections at the solenoid correct.
Resistor wire to the outside (RH side)
Purple (fat wire inside terminal)
1969 Camaro
KMG69 is offline
post #3 of 7 (permalink) Old Nov 3rd, 09, 10:32 AM
prostreet69camaro's Avatar
Is the car in park or neutral...neutral safety switch. Move the shifter back and forth with the key in the start position and see if the starter turns. Be careful if it is out of gear and tries to start. Have your foot on the brake pedal.
prostreet69camaro is offline
post #4 of 7 (permalink) Old Nov 3rd, 09, 10:45 AM
Ken
Gary,
I guess Mike and I are fishing for more information. Year, trans, engine, etc. It would be a big help.
Ken
1969 Camaro
KMG69 is offline
post #5 of 7 (permalink) Old Nov 4th, 09, 06:56 PM
Keith
if you've replaced the battery/starter/etc already, I swould say Neutral safety switch?
Is it a column shift (or former column shift that wa smoved to the floor? (if so, make sure the columne shift is rotated all the way to whwere the "park" position should be.
Otherwise, pull the neutral safety switch connector off o the switch and install a "jumper" to see if that solves your problem...
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
keithl1967 is offline
post #6 of 7 (permalink) Old Nov 4th, 09, 07:50 PM
Kev
Make a long #10 wire with alligator clips on each end and engage the solenoid from the battery with the car in park or neutral. This eliminates the ignition switch NSS, and related wiring, or indicates that's where the problem is.
Use half a set of jumper cables to temporarily replace the big ground cable. Don't remove or loosen the ground cable. Try to start the car.
Do the same with the big positive cable.
Almost free, simple and fast... Test first, replace parts later.
67sc is offline
post #7 of 7 (permalink) Old Nov 5th, 09, 01:21 PM Thread Starter
Gary
Thanks for all the replies - it was a bad neutral safety switch.
The previous owner really buthered my underhood wiring and I'm considering replacing the harnesses (both the engine harness and front light harness) - on a scale of 1-10, just how difficult is this to do? I'd like to do the dash harness also, but I'd like to tackle the underhood wiring first. The dash looks way more intimidating.
