Courtesy/Sail Lights - How should they work? - Team Camaro Tech
post #1 of 6 (permalink) Old Nov 5th, 09, 04:05 PM Thread Starter
67RS
Rewiring a 67RS with deluxe interior.. I got it with the harness out and have slowly been wiring it back together.. One thing that is not clear is how the sail panel lights, courtesy lights, door switch and headlight detents all work?
Would really appreciate any other 67 deluxe owners shedding some light on how it "should" work...
1.) Door jam switches are SPST on both doors.. Correct?
2.) Did 67RS deluxe interiors have under dash courtesy lights?
3.) Are the sail panel lights triggered by either the driver or passenger door opening? Do the headlights have to be on first before they come on?
4.) Did the sail panel lights also come on by turning the headlight switch to the first detent?
5.) Did deluxe interior have under dash courtesy, dome, and sail panel lights? Were they all tied together?
deere2210 is offline
post #2 of 6 (permalink) Old Nov 5th, 09, 04:30 PM
Re: Courtesy/Sail Lights - How should they work?
1) Yes.
2) Optional. If you don't have them, add them- They are great!
3) Yes. Headlights on or off- doesn't matter.
4) Yes, by turning the switch all the way.
5) I think deluxe int got you the sail panels and no dome. That's how mine came anyway. If you have a console, also has a light at the rear of the console that works same as the sail panel lights and courtesy lights, in other words, all tied together.
Melrose RS is offline
post #3 of 6 (permalink) Old Nov 5th, 09, 04:32 PM
#1 yes
#2 yes
#3 a yes, b no
#4 no if you turn the headlight sw counterckockwise the should light.
#5 a yes, b no dome, c yes ansd all on same circut, Did not have dome light, had sail
panel, and under dash lights.
john68 is offline
post #4 of 6 (permalink) Old Nov 6th, 09, 09:16 AM Thread Starter
67RS
Thanks for the quick response! Definitely helps understanding how they should work while tracing through everything..
post #5 of 6 (permalink) Old Nov 6th, 09, 01:29 PM
If your not concerned about originality, add the dome...the sail panel lights look cool but arent really practical for reading a map or something from the front seat
________________________________
1967 RS 460 BB, TKO 600, 3.42 12 Bolt posi
mpaq is offline
post #6 of 6 (permalink) Old Nov 6th, 09, 02:20 PM
Exactly! It's super dark in the front. That's why the under-dash courtesys are a must add, too. Like when you drop your cell phone on the floor and can't find it in the dark.
