MAD Electril Oil Pres Sw in fuel pump circuit - PIC - Team Camaro Tech
post #1 of 3 (permalink) Old Nov 8th, 09, 12:55 PM Thread Starter
I am running the MAD electric oil pressure switch in my fuel pump electric circuit. For this, I need a place to mount the Chevy Vega sender in my 502. First, please verify that the plug just above the oil filter is for my Oil Pressure Sender servicing my gauge.
Moving to the left there is another plug, what is this? Is it also oil pressure? Next picture continues to move left and shows on more at the front of the block. On the other side, I have the same type plug around center of side. Are all three of these for oil pressure?
Clean 67 - 502 inbound
St Petersburg, FL
mccomas is offline
post #2 of 3 (permalink) Old Nov 8th, 09, 04:09 PM
prostreet69camaro's Avatar
Re: MAD Electril Oil Pres Sw in fuel pump circuit - PIC
The one above the filter can be used for oil pressure and the one in front on the drivers side is for oil pressure. Doesnt mater which one you use. The 2 in the middle are in the water jackets and can be used when you want to drain the antifreeze out of the block when you remove the intake or heads. That way water will not go in the motor.
prostreet69camaro is offline
post #3 of 3 (permalink) Old Nov 14th, 09, 07:08 AM Thread Starter
The first pic below is the Vega 3 terminal switch. It looks like 1/8 inch NTP can anyone confirm this? The size of the oil pressure port on the block looks to be 1/4 inch NTP - can anyone confirm this for the 502 block?
I need some type of adapter like the one in the 2nd pic. Any suggestions???
St Petersburg, FL
mccomas is offline
