Back up light switch adjustment horse shoe shifter - Team Camaro Tech
post #1 of 5 (permalink) Old Nov 17th, 09, 04:48 PM Thread Starter
Patrick
Anyone know if there is an adjustment to this switch? I see the switch with the pink wire.
My back up lights come on in reverse AND neutral sometimes. The switch needs to be moved farther foward?
Any pics would be great.
Thank you in advance.
1968 Convertible L92 VVT project, Hotchkiss lowering front & rear.
68problemchild is offline
post #2 of 5 (permalink) Old Nov 17th, 09, 04:53 PM
Re: Back up light switch adjustment horse shoe shifter
Loosen the two screws on the side of the switch body and rotate the body to satisfy all needs; tighten screws.
post #3 of 5 (permalink) Old Nov 17th, 09, 04:59 PM Thread Starter
Patrick
Thanks. I see one screw towards the front of the switch and one to the rear. On the sides are bolts holding the horse shoe shifter?
I assume you mean the screws?
Thanks so much.
PS, I give. How do you angle anything on that rear screw? PB blastered and am sleeping while it soaks.
post #4 of 5 (permalink) Old Nov 17th, 09, 05:08 PM
Yes..."screws on the switch body", not the shifter.
Just be sure to take a look at the shifter alignment with the detent plate. It may be that your shifter cable isn't adjusted correctly. Put the transmission in neutral and make sure the shifter aligns with the neutral detent. If that looks good, commense adjusting the switch.
dnult is offline
post #5 of 5 (permalink) Old Nov 18th, 09, 06:06 PM Thread Starter
Patrick
Got it. Small socket swivel bought today did the trick plus some pb blaster overnight.
Works good now.
Thanks guys. You saved me a week of trial and error.
