67 Turn Signal Does Not Blink - Team Camaro Tech
post #1 of 8 (permalink) Old Nov 18th, 09, 02:28 PM Thread Starter
The left front turn signal on my 1967 does not blink, and the left front flasher does not flash. The left front parking light does work. All other lights work and flash correctly. Installed new bulb - no fix. Any ideas on what may be causing this problem? Thanks!!!
lmtrader is offline
post #2 of 8 (permalink) Old Nov 18th, 09, 02:48 PM
Re: 67 Turn Signal Does Not Blink
Did you check the ground wire?
Sauron67MM is offline
post #3 of 8 (permalink) Old Nov 18th, 09, 03:26 PM Thread Starter
Scott,
This is my first Camaro. Can you help me where to locate and check the ground?
Thanks!
lmtrader is offline
post #4 of 8 (permalink) Old Nov 18th, 09, 03:48 PM
Check out this pic. It might help. The black with with the ring at the end is the ground.
http://www.rickscamaros.com/product....dept%5Fid=3311
Take the bolt/screw out of the ring and clean both thr ring and the mounting point with sandpaper. Make it nice and clean - meaning - no rust.
When you put it back, I'd use one these (star washer) if it already doesn't have it on there.
Dan
'68 Camaro Convertible
dschribs is offline
post #5 of 8 (permalink) Old Nov 18th, 09, 03:48 PM
Certainly. There is a black wire on the back of the lamp housing that attaches to the headlight housing.
post #6 of 8 (permalink) Old Nov 18th, 09, 03:52 PM
Check/clean all the connections while you have your head in there. Junction block behind battery, connections at the horn relay and voltage regulator and all the other grounds.
post #7 of 8 (permalink) Old Nov 18th, 09, 04:18 PM Thread Starter
Dan and Scott:
Thank you for your help.
lmtrader is offline
post #8 of 8 (permalink) Old Nov 18th, 09, 04:22 PM
Alan
Had the same problem. Connector behind the light had some gunk in it. Separated the connector, a few swipes with a toothbrush, good as new. I put some dielectric grease in there to keep the goblins out.
alan
alanrw is offline
