Heater won't turn on - Team Camaro Tech
post #1 of 3 (permalink) Old Nov 21st, 09, 02:14 PM Thread Starter
Josh
I just re-wired the car with an AAW Classic Update kit, and I can't get the heater to work. The is nothing wrong with the blower (works with constant power source), and I have power to both sides of the fuse on the fuse block.
The issue comes in that the orange wire going from the fuse box to the heater controls does not have a current. I was goin to pull the fuse box off the cowl and make sure the wire wasn't being crushed, but I wanted to know if anybody had any other ideas (or if I'm completely off base somewhere). I have tried in both the accessory and on ignition positions.
Thanks in advance
-Josh
iusamson is offline
post #2 of 3 (permalink) Old Nov 21st, 09, 03:25 PM
Fred
Re: Heater won't turn on
Isn't that a resistor on top of the heater box, in front of the glove box? Thought that controlled the lower fan speeds? Not sure. Do you have it?
128.79mph 1.428 60'
Fred Ficarra is offline
post #3 of 3 (permalink) Old Nov 21st, 09, 03:59 PM Thread Starter
Josh
The wire goes from the fusebox to the heater controls switch, and there is a seperate dongle from there that goes to the resister (just purchased new..already thought that was my issue) that is mounted on the top of the heater box (to keep the resistor coils cool.
iusamson is offline
