horn does not shut off - Team Camaro Tech
post #1 of 8 (permalink) Old Nov 27th, 09, 05:55 PM Thread Starter
i have a problem with the horn . i see there is a horn relay where would this be ? i have a 95 camaro, one horn was totally rotted away went to junkyard got two used ones tested with plug in and grounded horn works but will not shut down . any help will be helpful thanks
bob ball is offline
post #2 of 8 (permalink) Old Nov 27th, 09, 06:38 PM
Re: horn does not shut off
Sounds like a short. I'd start at the horn button on the steering wheel.
68 Camaro~LSx ~all motor
post #3 of 8 (permalink) Old Nov 28th, 09, 05:30 AM Thread Starter
alright i have two horn buttons replaced at the junkyard with black plastic piece that goes into hole that has connection to the air bag hockey puck[?] .1. put a ohm meter on the connections of the push buttons the red and black wires and i have a connection meaning the meter shows a reading. know this is with no horns hooked up don't know if that matters? but i was under the impression that there is no complete circuit until the horn button is pressed ? am i wrong here?
bob ball is offline
post #4 of 8 (permalink) Old Nov 28th, 09, 05:57 AM
That would be correct.... unless there's a short...somewhere.
post #5 of 8 (permalink) Old Nov 28th, 09, 08:35 AM
There will be a complete path through the relay coil, although the resistance will be more than a dead short.
dnult is offline
post #6 of 8 (permalink) Old Nov 28th, 09, 09:17 AM Thread Starter
o.k. would anyone know where the horn relay switch would be and could this be causing the short ? i guess my only chance is too trace the wires from the horns back ? and i'm not sure if the wire colors will stay the same at the bottom of the steering column?
bob ball is offline
post #7 of 8 (permalink) Old Nov 28th, 09, 10:44 AM
I don't own a 95, but I'd presume the horn relay is located in an under-hood fuse block. Check your owners manual. As far as wire colors go, you'll need a schematic for your vehicle.
dnult is offline
post #8 of 8 (permalink) Old Nov 28th, 09, 04:29 PM Thread Starter
thanks .
bob ball is offline
