69 Horn Relay problem - Team Camaro Tech
post #1 of 5 (permalink) Old Dec 2nd, 09, 10:57 AM Thread Starter
Hi everybody. I am new to this site and it looks awesome. I am replacing the turn-signal assembly and after installing and hooking up the harness my Horn Relay now emits a loud buzzing noise. This noise stops when I unplug the Hot wire from the relay that is coming from the steering column.
Does the horn Relay just need to be replaced???
Kent
kkeller73703 is offline
post #2 of 5 (permalink) Old Dec 2nd, 09, 11:18 AM
Trevor
Re: 69 Horn Relay problem
I had that problem as well,It was contact chatter. I had to bend the contact arm open a bit. Do this with the battery disconnected.
1969 SS 454ci TKO 600
Alberta69SS is offline
post #3 of 5 (permalink) Old Dec 2nd, 09, 11:23 AM
The buzz can also be "Key-in-the-ignition." Remove the keys or the pink wire to disable forever, at least until the pink wire is plugged back in.
post #4 of 5 (permalink) Old Dec 2nd, 09, 11:59 AM Thread Starter
Hey thanks! The problem persists when the key is in the ignition AND the car is running???? So not sure about the "key-in" possibility....
post #5 of 5 (permalink) Old Dec 2nd, 09, 12:03 PM
Only with the ignition off and key in the ign/tumbler should the buzzer be buzzin'.
