Original radio in 69 Z with an Ipod setup. - Team Camaro Tech
post #1 of 8 (permalink) Old Dec 3rd, 09, 06:12 PM Thread Starter
Guys,
I am trying to see how I would do this. I want to keep my original radio in my 69 Z but would like to be able to hook up an Ipod setup to it somehow.
Any suggestions?
soccerstudbr is offline
post #2 of 8 (permalink) Old Dec 3rd, 09, 06:23 PM
Andrew
Andrew69's Avatar
Re: Original radio in 69 Z with an Ipod setup.
You might try this. I may when I get a little time. https://www.camaros.net/forums/showthread.php?t=167275
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #3 of 8 (permalink) Old Dec 3rd, 09, 06:37 PM
If your radio happens to be AM/FM, then you can just use an FM modulator unit in the antenna line.
You Can't Fake Indifference
69 Camaro Convertible
57 Chevrolet Nomad
Jeeps
buzzworth is offline
post #4 of 8 (permalink) Old Dec 3rd, 09, 07:40 PM
Kevin
KevinW's Avatar
Brain, store the original radio and get another AM and have it converted to a AM/FM/MP3 unit, that is what I did (not installed yet though)
Kevin
KevinW is offline
post #5 of 8 (permalink) Old Dec 3rd, 09, 08:23 PM
Paul
This is what I did, after seeing what a few others have done with theirs ...
I reinstalled an original AM radio in the original location and installed a modern stereo in the glove box. The AM radio is hooked up to the front speaker. I unfolded the cheap cardboard glove box, traced it onto a piece of sheet metal, folded it into the correct shape and welded the box tabs together. It fit the first try and is solid. The radio does penetrate the back of the glove box thru a field cut out and had to be offset to the left because of the heater box. I flocked the inside of the metal glove box after test fitting and left a gap below the vinyl wrapped/wood mounting plate so you can still use the bottom of the glove box. The 1/8" stereo cable is routed to my MP3 player . The unit I installed has a remote control.
Next I need to add an amp and subwoofer to over power the 454 .
1969 Z/28 Camaro X77 Hugger Orange
OneNineSixtyNine is offline
post #6 of 8 (permalink) Old Feb 27th, 10, 05:34 AM
Andrew
Andrew69's Avatar
Hey Kevin-
Who did your conversion for you?
Andrew
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #7 of 8 (permalink) Old Feb 27th, 10, 07:13 AM
Bert
Ditto OneNineSixtyNine I did the same in my 67rs and put an amp/sub in but do not have the original am/fm so hooked up front speakers to system for pretty good sounds,,,not as nice as the 327 though Needing some sort of dummy radio or block out plate to finish
67rssince77 is offline
post #8 of 8 (permalink) Old Feb 28th, 10, 01:45 PM
Kevin
KevinW's Avatar
Originally Posted by X33D80 View Post
Hey Kevin-
Andrew
Andrew, Joe C. did the conversion. I recently did a test hookup and it played great.
http://mysite.verizon.net/vze6kave/index.html
Kevin
KevinW is offline
