Interior Wiring Help! - Team Camaro Tech
post #1 of 3 (permalink) Old Dec 4th, 09, 01:25 PM Thread Starter
walt
Question Interior Wiring Help!
I have a groung clip that hooks to the brake pedal push rod. where is the wire that hooks to that ground clip? thanks!
easyrider is offline
post #2 of 3 (permalink) Old Dec 4th, 09, 01:43 PM
Re: Interior Wiring Help!
Assuming you are talking about the flat, oblong piece of metal that fits over the brake pedal shaft, that's a clip for the return spring for a manual brake car. The other end of the spring went to the pedal bracket, hole in the top. Nothing grounds to the pedal.
Eric
Eric Kammerer is offline
post #3 of 3 (permalink) Old Dec 4th, 09, 01:51 PM Thread Starter
walt
The clip attaches to the brake pedal pushrod, and it has a tang on the end of the clip for a wire to attach
