67 RS Headlight Wiring - Team Camaro Tech
post #1 of 9 (permalink) Old Dec 7th, 09, 08:27 AM Thread Starter
RONNIE J
ambrola's Avatar
Does anyone have the skymatics on the original wiring of the headlight system?? I looked every where on here, and can't find it???
RONNIE 67 NUMBERS MATCHING RS
ambrola is offline
post #2 of 9 (permalink) Old Dec 7th, 09, 08:32 AM
Re: 67 RS Headlight Wiring
Here's one
http://www.pozziracing.com/Media/67rswire.jpg
This site is helpful also.
http://www.retro-electro.net/FAQ.html
good luck. If you can tell us what it's not doing, we may be able to provide additional help.
Melrose RS is offline
post #3 of 9 (permalink) Old Dec 7th, 09, 02:09 PM Thread Starter
RONNIE J
ambrola's Avatar
Thanks for the help guys. I just never finished the headlights on the RS. I decided to use the original parts that are still good. Not that it matters that it is original, I just think I can fix the old ones alot cheaper??
ambrola is offline
post #4 of 9 (permalink) Old Dec 7th, 09, 09:36 PM
Matt
if your motors are still good then it should be doable. If they are shot then check out the Retro-Electro kits...I have one and love it.
Matt
zlek131 is offline
post #5 of 9 (permalink) Old Dec 10th, 09, 04:32 PM
Vaughn
I attached a drawing I made of the wiring in more of a ladder drawing electrical form. I had trouble with the "race" between relays R1 and R3. If R1 is faster then R3 to OPEN the doors, there is a short to ground at R3. If R1 is slow to de-energize on a CLOSE, then there is another short ot ground through R3. I installed an inductor between R1-3 and R3-3 to slow the current down from R1 to R3 and add in a little resistance. Seems to work good with the inductor in.
starboard is offline
post #6 of 9 (permalink) Old Dec 15th, 09, 11:51 AM
Hi all I have a question I have the retro electric motors and all new relays and all new switches My doors start to open and the driver side does but as soon as the pass side comes off the switch it stops? The driver side works fine? I just replaced the old motors that were after market they were old and rusted in the gear boxes. any help thanks Sory to jack the thread but may help us all .
Da67kid is offline
post #7 of 9 (permalink) Old Dec 15th, 09, 12:02 PM
Dan- does pushing the pass side switch allow the motor to continue opening the headlight door? If yes, check the pass side switch to see if it has GND when both button pushed or not pushed. The motor should get GND through this switch when opening the door. Could be incorrect wiring/poor connection at the switch.
see this schematic. Good luck. http://www.pozziracing.com/Media/67rswire.jpg
post #8 of 9 (permalink) Old Dec 15th, 09, 12:07 PM
Matt
Dan,
I would call Mark at Retro-Electro. He knows these things inside and out. He should be able to fix you right up...
Matt
zlek131 is offline
post #9 of 9 (permalink) Old Dec 15th, 09, 12:22 PM
thanks i will give it a shot
Da67kid is offline
