Alternator Bracket ?? - '69 Camaro - Team Camaro Tech
post #1 of 18 (permalink) Old Dec 15th, 09, 07:09 PM Thread Starter
Andrew
Andrew69's Avatar
I have this bracket for the alternator but cannot figure out where the arm extension is to attach. There seems to be no obvious reason for having that extension. What am I missing?
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #2 of 18 (permalink) Old Dec 15th, 09, 07:28 PM
mark
mark x22's Avatar
Re: Alternator Bracket ?? - '69 Camaro
there is a place on the back of the alternator to bolt to . some after newer ones may not have it .
mark x22 is offline
post #3 of 18 (permalink) Old Dec 15th, 09, 08:21 PM
JAY
Bolts to back of Altenator on my 69 Camaro
jay
JAYARTER is offline
post #4 of 18 (permalink) Old Dec 15th, 09, 09:36 PM
Kurt
camsdad's Avatar
69 SB Alternator support spacer bracket between Alternator and Passenger side (R) head.
Long bolt goes through the Alternator through the spacer and bolts to the head.
Tab bolts to the Alternator.
See detailed drawing on page 75 of the 1969 Camaro factory assembly instruction manual.
Kurt
1969RS 14yrs into it.
383CID Lives
200R4 Trans, 3:42 Posi 12 Bolt Ready
Cold ones in the fridge. Dam, there gone. BRB
Getting closer to my goal.
camsdad is offline
post #5 of 18 (permalink) Old Dec 16th, 09, 05:43 AM Thread Starter
Andrew
Andrew69's Avatar
Okay... thank you... I thought it might be that. The alternator on the car is stamped #1100834, a dated '70 model off a typical small block. I wish I had the # 1100837 for the '69 Z, but they go for major bucks.
So unless I run upon a 837 alternator I will continue to wrap that arm up under the alternator.
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #6 of 18 (permalink) Old Dec 16th, 09, 03:04 PM
1100834 should have the threaded boss on the back to accomadate the bracket. You must have the wrong rear case on the 834.
stellar is offline
post #7 of 18 (permalink) Old Dec 17th, 09, 06:18 PM
madmax87's Avatar
You can see in this pic pretty good where it goes. That is the only support for the rear of the alt.
madmax87 is offline
post #8 of 18 (permalink) Old Dec 19th, 09, 08:21 AM Thread Starter
Andrew
Andrew69's Avatar
Thanks for the photo Dennis. Either the rear of my alternator is incorrect, or my spacer with the arm is incorrect. My spacer's arm has a span of 3.5" between the center bore and the arm's mounting hole. I suspect the arm. Who out there has one you can measure for me?
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #9 of 18 (permalink) Old Dec 19th, 09, 09:43 AM
mark
mark x22's Avatar
Mine is installed and hard to measure but look to be about 2.8 .do you have a threaded hole at all ?
mark x22 is offline
post #10 of 18 (permalink) Old Dec 19th, 09, 10:10 AM
mark
mark x22's Avatar
Found an old alternator it is 2.62
mark x22 is offline
post #11 of 18 (permalink) Old Dec 19th, 09, 06:04 PM Thread Starter
Andrew
Andrew69's Avatar
Many thanks! This tells me that I need the correct bracket spacer tube with the 2.62 distance arm. I don't remember where I got this one, it may have been eBay, if so it was misrepresented.
Is there any stamping or ID on your part? The bracket in my photo above isn't actually the one on the car, that part photo was found on eBay and it is still available. Maybe I will buy it.....
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #12 of 18 (permalink) Old Dec 19th, 09, 06:18 PM
mark
mark x22's Avatar
I cant see anything with it on the car . did your alternator have the hole ?
mark x22 is offline
post #13 of 18 (permalink) Old Dec 19th, 09, 06:37 PM Thread Starter
Andrew
Andrew69's Avatar
My alternator does have the mounting hole on the back, and it measures ~ 2.6" center-to-center between the holes. With your help I now know the problem is in the bracket and if I play my cards right I will buy the one off of eBay in a few days.
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #14 of 18 (permalink) Old Dec 22nd, 09, 06:45 PM Thread Starter
Andrew
Andrew69's Avatar
Well I won the eBay auction. A little sand blasting and painting and I'll be putting the correct bracket on the Camaro. Thanks for all your help.
http://cgi.ebay.com/ebaymotors/ws/eB...torefresh=true
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #15 of 18 (permalink) Old Jan 3rd, 10, 03:42 PM Thread Starter
Andrew
Andrew69's Avatar
I have sand blasted, primed, and painted the eBay purchased bracket and today braved the cold garage and installed it. Thanks for your help guys, below is a photo.
I have also included a photo of the old bracket with a span of 3-5/8" on the arm and it has "AAC" stamped on it. What would this have come off of? If I can identify it I will sell it on eBay.
Thanks,
Andrew
Name:	Alternator Bracket 001.jpg
ID:	13593   Click image for larger version
Name:	Alternator Bracket 002.jpg
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
