69 tach dash conversion question - Team Camaro Tech
post #1 of 5 (permalink) Old Dec 18th, 09, 11:53 AM Thread Starter
I want to convert my 69 standard dash to a tack/clock dash, put in the factory gauge pod on the center console AND GET ALL THESE ITEMS HOOKED UP CORRECTLY with no hidden problems if possible. I have read as many of the search posts as I can find. With that info I went to order the items needed and was told by the sales rep. that if I went that route that along with everything else I would have to make at least three wire changes at the fuse block which is not really something that can be done like the factory would.
He said to purchase all the needed full wiring harnesses and replace all the harnesses, fuse block, etc. This would be a bunch more money.
I would like to know if this is completely true or a bit of a sales pitch.
If anyone that has done the conversion can shed some more light on this subject, it would be great. Thanks
justsomeguy is offline
post #2 of 5 (permalink) Old Dec 18th, 09, 12:49 PM
Re: 69 tach dash conversion question
To fit the tach, you need the tach harness which is attached externally to the engine harness and passes through a hole in the firewall next to the bulkhead connector. See RPO U16-A1 of the factory assemby manual for diameter and exact location details
You need harness CA6907
The console gauge harness, CA97579 auto or CA97581 manual trans, plugs into the main loom where the non-console gauge harness should already be pluged in.
See RPO U17-A1
The in-dash clock harness, CA97523, plugs into the fuse box terminal labelled "BAT-FUSED".
See RPO U35-A1
Apart from drilling one hole by the bulkhead connector for the tach harness to pass through (it comes with the correct grommet), there is really nothing else to do but plug the looms in.
BlackoutSteve is offline
post #3 of 5 (permalink) Old Dec 18th, 09, 01:19 PM
Just looking at the AmericanAutoWire website.. http://www.americanautowire.com/#
You may require a "Console gauge conversion harness".
Download this catalog for the part number that suits your application.
http://www.americanautowire.com/cata.../03_CAMARO.pdf
Contact them if you are unsure if it's what you need.. I'm unsure!
post #4 of 5 (permalink) Old Dec 18th, 09, 03:17 PM
mark
mark x22's Avatar
the U17 tach wire with console gauges goes in the main harness and the bulkhead connector . Option U16 tach and center fuel gage had the separate tach wire like Steve mentioned . buy the conversion harness and a roll of wire harness wrapping tape and you can make it look nice .
mark x22 is offline
post #5 of 5 (permalink) Old Dec 19th, 09, 02:01 AM
Yeah Mark, I just opened my CA6907 tach harness, and it has the connectors to pass through the bulkhead connector, which is a much easier retro fit.
It also comes with the correct grommet, so you can cut the spade terminals off and rejoin the wires together and use the tach hole if you already have one drilled. (You'll never get the spade terminals through that grommet!)
