Headlight connector / plug - Team Camaro Tech
post #1 of 5 (permalink) Old Dec 20th, 09, 07:11 AM Thread Starter
I am unable to find this connector anywhere looking for the black plug housing and the internal connectors. This is the plug for headlights. The internal push on connectors are a bit wider than standard connectors I have seen. Any suggestions on where to buy this?
Clean 67 - 502 inbound
St Petersburg, FL
mccomas is offline
post #2 of 5 (permalink) Old Dec 20th, 09, 08:28 AM
Rick
Re: headlight connector / plug
googled it
http://www.rockauto.com/catalog/rafr...1321210k274892
Rick
68 project...reassembly starting: (383, AFR 195, Air Gap, Comp Cam XR276HR, 1.6 CC Gold rollers, Holley 750, 4/09) (TKO 600 conversion from T350 4/09) (floor pan restored 6/09). (12 bolt 3.73, Wilwood disc, Hotchkis TVS 7/09), Dougs 368 with Big Dog mufflers (9/09), 383 fired up 9/30/09, Candy Apple Red 2012 with white RallyBee stripe
dukemd66 is offline
post #3 of 5 (permalink) Old Dec 20th, 09, 11:34 AM
Kevin
KevinW's Avatar
Got a bunch of those on junk harnesses, but you are going to have to splice the wires if you are missing the connectors.
Kevin
KevinW is offline
post #4 of 5 (permalink) Old Dec 20th, 09, 12:41 PM
You can probably replace ther terminals in the connector instead of splicing. The terminals usually (haven't done headlamps) have a little retainer tab that you have to depress with a brad nail or other long slender object. Get a new terminal and crimp it onto your existing harness.
dnult is offline
post #5 of 5 (permalink) Old Dec 20th, 09, 02:31 PM
American Auto Wire sell those larger terminals. The rest of these cars use a Packard 56 series, but these headlamp terminals are Packard 59 series and are part number 500188. $4 buys 10.
The 3-terminal plastic connectors are part number 500196 and they're $4 each. (..but you can re-use your existing connestors af you want buy removing the terminals. Use a tiny flat blade the flatten the tang within.)
http://www.americanautowire.com/index.html
See page 41 of.. http://www.americanautowire.com/catalogs/2009AAW.pdf
You'll need the right crimpiners (see page 55), but MSD sell these too and are modular with different jaws available to suit the one pliers.. I have these and I love them!
See pg 132 of the MSD catalog. 35051 with 3506 are the jaws you need.
http://www.msdignition.com/page.aspx?id=6537
BlackoutSteve is offline
