Brake lights not working? - Team Camaro Tech
post #1 of 22 (permalink) Old Dec 21st, 09, 01:51 AM Thread Starter
i have a 67 camaro and recentl my brake lights decided not work. i replaced the brake switch and checked the fuse. any ideas why both lights arent working now. when my headlights are on the rear lights work just not the brake lights? please advise?
brianstevens03 is offline
post #2 of 22 (permalink) Old Dec 21st, 09, 02:42 AM
Bruno
Lightbulb Re: brake lights not working?
On our cars, the stop circuit goes thru the turn signal mechanism, so you might need to check that area too. That if you don't have 12 volts at the lamp sockets while depressing the brake pedal. Bad lamps or sockets are the first things to check tho. This wiring diagrams should help you trace the brake signal, from the stop switch all the way to the trunk. Look for 12 volts at the brake switch and follow the wire colors shown on the diagram. http://www.gvtc.com/~rlaa/
"Our affair with Camaros is a life sentence without the possibility of parole".
ORENCH is offline
post #3 of 22 (permalink) Old Dec 21st, 09, 03:48 AM
Emergency flashers overrule all other circuits.
If flashers work, then proceed with Orench's suggestion of turn signal switch, maybe giggle the handle.
If brake lights don't work, power to brake switch? Through switch? Power to fuse panel?
post #4 of 22 (permalink) Old Dec 21st, 09, 04:18 AM
Re: Brake lights not working?
On the 67 and 68 models, the rear lights ground through the metal housings. It is very common for a bad ground there to make the brake lights stop working. Try removing the light sockets and clean up the area where they contact the housing with some 180 sandpaper or steel wool. Clean up the little metal tabs on the light sockets themselves too.
If that works, you'll just need to maintain a good connection. I got tired of doing that on my 68 and swapped the sockets with parts store replacements that had a ground wire, and grounded the sockets to the trunk latch brace, like a 69.
Eric
Eric Kammerer is offline
post #5 of 22 (permalink) Old Dec 21st, 09, 04:33 AM
Bruno
Post Re: Brake lights not working?
Me too.
ORENCH is offline
post #6 of 22 (permalink) Old Dec 22nd, 09, 02:02 PM Thread Starter
ive got lights working when my turn signals are on, flashers, headlights just not brake pedal. not a fuse. hmmm? i replaced the switch.any ideas? if so how?
post #7 of 22 (permalink) Old Dec 22nd, 09, 03:21 PM
prostreet69camaro's Avatar
Have you tried testing the wiring with a test light or meter. Start at the brake switch. It has a orange and white wire on the switch. See if you have power on the wires. You should have it on one side of the switch and when press the pedal and you should have it on the other wire. Then work your way to the trunk and test the wires there.
prostreet69camaro is offline
post #8 of 22 (permalink) Old Dec 22nd, 09, 05:20 PM
Jeff
yellow69RS's Avatar
Based on the above I'm guessing that the brake light works with the turn signal. I think the T/S switch is bad. If the turn signals work that pretty much rules our the bulbs and sockets.
Jeff
yellow69RS is offline
post #9 of 22 (permalink) Old Dec 22nd, 09, 06:12 PM
The brake lights go thru the turn signal switch on the white wire.
post #10 of 22 (permalink) Old Dec 23rd, 09, 07:18 PM Thread Starter
but my turn signals work, could it still be the turn signal wiring? im lost!
post #11 of 22 (permalink) Old Dec 23rd, 09, 07:20 PM Thread Starter
rear lights work when headlights are on and turn signals work and hazards work.
Ive checked....
fuse
power to brake switch(power on one side)
sockets
bulbs
post #12 of 22 (permalink) Old Dec 24th, 09, 02:26 AM
Bruno
Lightbulb Re: Brake lights not working?
Test with the turn signal working to one side, then have someone depress the brake pedal and see if the signal keeps blinking. Then same test to the other side. If the blinking stops while the brake pedal is depressed, most probably your turn signal switch is defective.
ORENCH is offline
post #13 of 22 (permalink) Old Aug 28th, 10, 07:50 AM
Peter
I'm having the same problem. Where is the turn signal switch located? Sorry, I'm just not certain on this vehicle. Thanks in advance for your help.
utah67 is offline
post #14 of 22 (permalink) Old Aug 28th, 10, 07:58 AM
Alan
Recheck at the switch, it wouldn't be the first time a new switch was bad.
alan
alanrw is offline
post #15 of 22 (permalink) Old Aug 28th, 10, 10:56 AM
Larry
larryh56's Avatar
Inside the steering housing. You need to pull the steering wheel to get at it.
68 RS Coupe 355/350 TH, Detroit Speed, Hotchkis, Vintage Air, 8.5" 3.42 posi 10-bolt, MagnaFlow 2 1/2" exhaust, etc.
"The public cannot be too curious concerning the characters of public men."
Samuel Adams
larryh56 is offline
