69 signal light problem - Team Camaro Tech
post #1 of 5 (permalink) Old Dec 21st, 09, 11:01 AM Thread Starter
JDCAST
Smile 69 signal light problem
Good Day- when I signal left the dash blinker blinks and the rear blinker operates but the front is lit but does not blink. I had the right side one working but now same thing--the rear blinks but the front lights but doesnt blink. Any ideas are appreciated. They are the original parking lights. Hate to replace with repros.
thanks--John C
jdcastig is offline
post #2 of 5 (permalink) Old Dec 23rd, 09, 06:52 PM
Re: 69 signal light problem
SO if I read this right, the dash light blinks, the rear light blinks, and the front light comes on steady when you indicate turn?
Have you tried replacing the flasher? May be weak?
Also, I would pull the steering wheel and inspect the turn signal mechanism in the column. Just some ideas.
Best of luck.
Pair of 69 Z/28 RSs
jmcbeth is offline
post #3 of 5 (permalink) Old Dec 23rd, 09, 07:21 PM
Send a message via AIM to RamAirDave
First (obvious) would be to check the bulbs themselves. Then make sure the pigtails from the housings are plugged in solidly into the front light harness.
Put a test light on the spades (don't recall which wire is running and which is signal, try both) inside the plastic connectors on the front light harness, turn the turn signals on. If the test light flashes with the signal, then it's connection or the housing. If not, then start working your way back checking the connection to the firewall bulkhead, column wiring connector, and so on.
Driving a #s-matching Z in the rain..... and lovin' it....
RamAirDave is offline
post #4 of 5 (permalink) Old Dec 24th, 09, 06:22 AM
SCOTT
I had the same problem on my car, when I was working on the electrical system, I had a bunch of bulbs laying around and used them. Come to find out I had put a couple of single element bulbs in to test the system. after an hour of trouble shooting it dawned on me what I had done. I put the correct bulbs in an wha la it works.
OL SCHOOL is offline
post #5 of 5 (permalink) Old Dec 26th, 09, 06:18 PM
Check the ground for the harness. Bad grounds do wierd things
xtra1299 is offline
