Voltage Reg - How Hot? - Team Camaro Tech
post #1 of 11 (permalink) Old Dec 22nd, 09, 06:59 PM Thread Starter
Ernie
1969 Camaro Voltage Regulator - Anyone know how hot is the norm on the back? I checked mine and it was about 300 degrees; is something wrong or is this normal? Thank You!!!
ernieandsandi is offline
post #2 of 11 (permalink) Old Dec 22nd, 09, 07:16 PM
Skip
Skeeter55's Avatar
Re: Voltage Reg - How Hot?
Sounds like a problem thats pretty hot.
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #3 of 11 (permalink) Old Dec 22nd, 09, 07:21 PM
I agree with Skip....300 degrees does'nt seem to be normal.
David F.
468 CID 661 Horsepower
Turbo 400
33"x19.50" Mickey Thompsons
post #4 of 11 (permalink) Old Dec 22nd, 09, 07:33 PM
130°F to 140°F would be normal when read on the cover.
Chassis would be hotter, but I don't think 300°F.
Temp gun? Shoot thermostat housing with same temp gun for a quick temp check.
post #5 of 11 (permalink) Old Dec 22nd, 09, 08:47 PM
Jerry R.
jr68's Avatar
Hey Ernie, hi buddy !
would it be possible for you to use an internal regulator alternator ?
my Magnaflow X-pipe system sound clip, click the link
jr68 is offline
post #6 of 11 (permalink) Old Dec 22nd, 09, 08:50 PM
Jerry R.
jr68's Avatar
p.s. love your motor . . .
jr68 is offline
post #7 of 11 (permalink) Old Dec 23rd, 09, 07:33 AM Thread Starter
Ernie
I used a temp gun to check temp on the regulatory. Front side was warm to touch but back side was burning hot (about 300). Jerry, I'm trying to keep it original looking so I don't want to go with the internal reg. alt.
post #8 of 11 (permalink) Old Dec 23rd, 09, 08:27 AM
You can change over to an electronic regulator and swap cover(s).
Wells P/N VR715.
post #9 of 11 (permalink) Old Dec 26th, 09, 09:45 AM
Jerry R.
jr68's Avatar
Ernie, the alternator looks like the original and wont hurt the replica look and you can leave your old regulator right in its place kind of dummy wire it up. No one will know.
jr68 is offline
post #10 of 11 (permalink) Old Dec 26th, 09, 08:15 PM
...Anyone know how hot is the norm on the back?
Are you measuring the component side of the regulator? If so, there are power resistors on the board that may get as hot as 100-150*C (200 - 300*F). If your case cover is 300*F that seems pretty darn hot, but I can't say that I've measured one before. Sometimes new tools (like an IR thermometer) will lead to all sorts of discoveries that will blow your mind.
dnult is offline
post #11 of 11 (permalink) Old Dec 26th, 09, 08:30 PM
"Tri-Tip"
Gary L's Avatar
Call John Pirkle and ask him. Then have him repair it if need be.
John's website
Gary L is offline
