Help with my horn problem - Team Camaro Tech
post #1 of 6 (permalink) Old Dec 27th, 09, 12:54 PM Thread Starter
JDCAST
Unhappy Help with my horn problem
My horn doesnt work on my 69 camaro. I put a test light on the wire that goes to the horn and no light. I put the test lite at the horn relay and it lites. So i replaced the horn relay and now when i toot the horn it just clicks at the horn relay but no horn. Any suggestions? I still get no test lite at the wire that connects to the horn. Im stumped.
Thanks --john
jdcastig is offline
post #2 of 6 (permalink) Old Dec 27th, 09, 12:56 PM
Re: Help with my horn problem
Horn(s) could be stuck. Try another horn to the green wire, any brand/type or test light to the green horn wire.
post #3 of 6 (permalink) Old Dec 28th, 09, 04:29 AM
BILL
SPARKY69's Avatar
rap on the horns to free up the crud inside!
SPARKY69 is offline
post #4 of 6 (permalink) Old Dec 28th, 09, 05:47 PM
Thanks --john
If you get no test light at the wire that connects to the horn and the relay is clicking then this wire is not getting power or the relay is not sending power out. Just because you have a new relay doesn't mean it's good.
I would double check to make sure the test light is grounded by touching the end that you used to touch at the wire at the horn to a known good power source. I've been caught before thinking I had my test light grounded only to be fooled.
Can you test right at the output terminal on the relay to see if there is power coming out when the horn button is depressed (and the relay kicks on) ?. I've seen crimped terminals on wires go bad too and it might be the terminal on the wire at the relay or at the horn end.
If all else fails, disconnect the wire from the horn and run a jumper from the horn terminal directly to the battery. If the horn is good, it should sound. If not, loosen the mounting bolt slightly to allow the horn to be wiggled and have it dig into fresh metal, and then retighten the bolt. If it then sounds with the jumper wire then try reconnecting the original green wire to it and see what happens.
SOA-Nova is offline
post #5 of 6 (permalink) Old Jan 2nd, 10, 08:59 AM
Kevin
I had to squirt WD-40 into mine as suggested to loosen up the horns, one worked again, the other does not and will need replacing ...
kmg1969ss is offline
post #6 of 6 (permalink) Old Jan 2nd, 10, 11:39 AM
As several others have mentioned, horns do rust and sieze up. But if you're not getting the test lamp to light up when connected to the horn wire, you have a wiring issue or a bad horn relay (even though the relay is new). The wire from the relay to the horn assembly is pretty short so you should be able to inspect it easily enough, do a continuity check and determine the cause.
dnult is offline
