Beginner's help with electrical issue - Team Camaro Tech
post #1 of 3 (permalink) Old Dec 30th, 09, 09:28 PM Thread Starter
Ok...so i have an 88 camaro v8. Just a few minutes ago while inserting a charger for my GPS, my radio, cigarette lighter, trunk, and locks seemingly stopped working. Is it possible that my wires are corroding or is there another reason? I'd like to have some idea before I take it to a mechanic and he/she tries to rip me. I can say that before this issue occured, my radio would turn off and on randomly...but then go back to normal for days.
Horg4423 is offline
post #2 of 3 (permalink) Old Dec 30th, 09, 09:45 PM
68driver57's Avatar
Re: Beginner's help with electrical issue
First, did you check your fuse box? Check to see if the fuse is blown, or loose, make sure the connections are tight and not corroded. Your radio problem could be a loose wire or a chafed wire. Next make sure all the grounds are good this is one of the main problems with older cars.
68 coupe
matching 327
95 coupe (bone stock)
68driver57 is offline
post #3 of 3 (permalink) Old Dec 30th, 09, 10:50 PM
Larry
if you don't stick the charger STRAIGHT into the lighter it's possible to contact power & ground and blow the fuse
Sometimes it's better to let someone think your an idiot, than to open your mouth and remove all doubt...
ls427ss is offline
Tags
electrical wiring
