69 Positive cable clips???? - Team Camaro Tech
post #1 of 4 (permalink) Old Jan 4th, 10, 10:46 AM Thread Starter
Ron
Does anyone know how to install the clips to the frame that holds the positive cable, there are 1/4" holes and the new clips I have have a rivet that is snug in the hole but how is this secured???? Thanks in advance, Ron
$uper$port is offline
post #2 of 4 (permalink) Old Jan 4th, 10, 11:45 AM
Fred
Re: 69 Positive cable clips????
Welcome Ron!
I've never removed the positive clips. They should just pop into the frame and stay put. Here's mine. The clip is in the center of the picture. The other one is not shown but it's near the starter. The correct holes should work with no other retainers. Remember; "assembly lines". Gotta be quick, but most of all not challenging to workers.
128.79mph 1.428 60'
Fred Ficarra is offline
post #3 of 4 (permalink) Old Jan 9th, 10, 08:44 AM
I've ruined a few of these clips trying to install them. Have never figured it out. It's almost like you need a punch where the tip expands when it is inserted into the middle of the rivet hole attached to the clip.
EricE
68 Butternut Yellow
SS Coupe 396/325
stope4 is offline
post #4 of 4 (permalink) Old Jan 10th, 10, 06:30 PM
Roger
rogerh's Avatar
What I did was to use a pop-rivet inside the clip fastener. I cut the barrel from another pop-rivet to use as a spacer to go through the clip. The pop-rivet expanded the clip fastener and it seems to be holding.
Roger
rogerh is offline
