Courtesy and dome lights not working - Team Camaro Tech
post #1 of 8 (permalink) Old Jan 4th, 10, 07:24 PM Thread Starter
jeff morrison
OK, I'm trying to finish up wiring under the dash. I installed AAW whole car wiring harness. I can not get power to any dome or courtesy lights. Seems like it may be a ground problem. Could the door jamb switches not be grounding correctly and keeping them from working? I have not replaced them and they do have paint on them.
Oh, it's a 67 standard, if that would matter. Thanks
layne02 is offline
post #2 of 8 (permalink) Old Jan 4th, 10, 08:58 PM
Roger
rogerh's Avatar
Re: courtesy and dome lights not working
Have you checked to see if you have 12 volts at the bulbs? Yes the door switches are the ground.
Roger
rogerh is offline
post #3 of 8 (permalink) Old Jan 4th, 10, 09:07 PM
my 67 had same problem.i ran a ground wire from my battery & touched switch still didn't work.i fooled with these for 3 days about drove me crazy.all my courtesy lights were new & came with the bulbs check & see if your bulbs are ones with double contacts or single contacts.you need the ones that only have one tit on the end of bulb.if yours is a double contact that's your problem.all my wiring was new & had the new bulbs in sockets but were wrong.the contacts I'm referring to are the part that's on the end of bulb that's down in socket.hope this helps.it could be a ground or a fuse also.i took a 3.00 volt meter from harbor freight & checked the bulb socket for voltage.if you have voltage to socket its most likely the wrong bulb.why mine had wrong bulbs is beyond me.sail panel lights take same bulb as under dash lights. auto zone napa & advance looked up my bulbs & said it called for the double contact bulbs but the aaw harness takes a single contact bulb.my old harness did take the double contact bulbs but the new harness don't
anthony hisle is offline
post #4 of 8 (permalink) Old Jan 5th, 10, 03:31 PM
Roger
rogerh's Avatar
Anthony how do you control the ground if like you said you have 12 volts at the socket? If AAW changed the circuits they should have a wiring diagram with the harness. It sounds like they have a relay in the circuit.
Roger
rogerh is offline
post #5 of 8 (permalink) Old Jan 5th, 10, 04:45 PM
That circuit get's it's power from the vlk/cty/ltr fuse, on the onrange wire.
Make sure you have 12 volts to all the sockets. make sure the lighter works, and the clock if equipped.
This circuit is weird to troubleshoot because it is backwards.
one sire of the bulbs is hot all the time, and the jamb switches put the ground in to complete the circuit.
Everything is in parrallel, so the only thing that can shut it all down is not having 12v on the orange wire.
post #6 of 8 (permalink) Old Jan 5th, 10, 06:33 PM
Roger
rogerh's Avatar
Jim that is the way the stock system works. The stock system also has double contact bulbs. Anthony is saying the AAW system has single contact bulbs. The old system can't work with single contact bulbs.
Roger
rogerh is offline
post #7 of 8 (permalink) Old Jan 5th, 10, 10:21 PM
i don't have a clue to be honest with you how it works.all i know i messed with these for 3 days & i had bulbs that had 2 contacts on them & they would not work.so i took a voltmeter & checked my sockets & they showed 12 volts but when i put in the single contact bulb they worked fine i bought new door switches threw autozone which would not work on my 67 they were to long & my doors would not shut so i put old door switches on & took my bulbs out of my old courtesy lights & they had two tits or double contacts & they would not light.OK thought i may got mixed up but i didn't.guys i have no ideal why it worked for me but i had bulb #clb-90 in the sockets i got these from carquest & this is what my original harness had in it would not work with the new aaw harness i bought so i then went to autozone & bought these bulbs name of bulbs are eiko#89 & it cured my headache worked perfect.i would try the # 89 bulbs first the most it will do is not work or blow a fuse.i know for a fact i have the single contact ones in my 67 because i went out to my garage & its like 16 degrees & pulled my bulbs out of my sail panel lights & my under dash lights & got numbers off of them for you.i read your post & i was thinking i might have told you wrong.but i told you right had me wondering if i had told you wrong.i hope you give it a try i believe if you use the #89 from autozone it will work.it about drove me insane trying to figure it out.bulbs are cheap & Advil is high.let me know if this fixes your problem because its worrying me to death thinking i may have mine hooked up wrong & take a chance on burning my car up.my lights are working great i opened doors & closed them 25 times to make sure the were working.im not saying the aaw harness is setup for a single contact bulb im pretty sure it has 2 contacts inside socket why the 2 contact bulb wont work is over my head,but the single one will
post #8 of 8 (permalink) Old Jan 12th, 10, 11:21 PM
Thanks you for the post.
Hi guys, Im a newbie. Nice to join this forum.
sharonk868 is offline
