Voltmeter - Team Camaro Tech
post #1 of 17 (permalink) Old Jan 11th, 10, 12:11 PM Thread Starter
Milt
Milt's 68 SS/RS 396's Avatar
Voltmeter
Not sure if this has been posted before, but i found a voltmeter on the Rick's Camaro website for the console gauge cluster. I had never seen one before & thought many folks here would want to convert from the funky amp gauge.
here is the link:
http://www.rickscamaros.com/find.asp...spec=voltmeter
Milt's 68 SS/RS 396 is offline
post #2 of 17 (permalink) Old Jan 11th, 10, 04:31 PM
Fred
Re: Voltmeter
Cool. I run both. The console unit is original and a voltmeter replaced the un-needed clock above the steering column. The amp guage is, well, useful, sorta.
128.79mph 1.428 60'
Fred Ficarra is offline
post #3 of 17 (permalink) Old Jan 11th, 10, 07:04 PM
Steps
Re: Voltmeter
Crap...$ US 119
http://www.rickscamaros.com/product....dept%5Fid=3447
Shipping will be about $US 70 plus insurance etc
So that makes it just under $US 200
Landed here $NZ 270 plus tax of 12.5%
I have never figured out why the Americans put Ammeters in their cars, which basically tell you nothing useful, yet all my old Vintage english cars have voltmeters.....
Steptoe is offline
post #4 of 17 (permalink) Old Jan 12th, 10, 12:57 PM
Fred
Re: Voltmeter
Originally Posted by Steptoe View Post
Crap...$ US 119
Shipping will be about 70 plus insurance etc
So that makes it just under 200
Landed here 270 plus tax of 12.5%
Ya know Steps, it might be because the manufactures thought we were too dumb to know what voltage readings represent.
128.79mph 1.428 60'
post #5 of 17 (permalink) Old Jan 12th, 10, 01:08 PM Thread Starter
Milt
Re: Voltmeter
I have a feeling the price will come down as more manufacturers start making them.
post #6 of 17 (permalink) Old Jan 12th, 10, 08:49 PM
Steps
Re: Voltmeter
I recon I can get one of my old gauges face, clean it off
use the guts out of another volt meter.
Then scan and resize to match the calibration of the volt meter being used, then print to a clear transfer....
Steptoe is offline
post #7 of 17 (permalink) Old Jan 13th, 10, 10:51 AM Thread Starter
Milt
Re: Voltmeter
Steptoe, you are one resourceful dude!
post #8 of 17 (permalink) Old Jan 13th, 10, 11:35 AM
James
Re: Voltmeter
here is the link:
Thanks for pointing that out. Its a great stock appearing alternative to the potentially hazardous amp gauge.
If you have ever seen the damage caused by an amp gauge or wiring short out, you would want to convert to volts!
68 Ragtop is offline
post #9 of 17 (permalink) Old Jan 13th, 10, 12:05 PM
"Tri-Tip"
Gary L's Avatar
Re: Voltmeter
here is the link:
Crap...$ US 119
It is not an ammeter. It is a milivolt meter that measures the voltage drop from the wire that goes from the connector behind the battery to the horn relay. Repeat, not an ammeter from the factory.
Gary L is offline
post #10 of 17 (permalink) Old Jan 13th, 10, 12:11 PM
Re: Voltmeter
Ive converted my factory ammeter to this unit and its great. I'm an early adopter and had a problem with an earlier unit as it grounding to the metal base plate of the factory gauge console. The screw studs were not adequately insulated. Returned and was sent a new gauge. Problem solved, its so much more useful to see voltage and the look blends right in.
69RSConvt is offline
post #11 of 17 (permalink) Old Jan 13th, 10, 04:01 PM Thread Starter
Milt
Re: Voltmeter
Wonder if they offer it in the black face.
post #12 of 17 (permalink) Old Jan 13th, 10, 04:56 PM
Re: Voltmeter
Yes its available
post #13 of 17 (permalink) Old Jan 13th, 10, 09:07 PM
Steps
Re: Voltmeter
OK lets split hairs
A ameter just tells one if it is discharging or charging.
A volt meter once one has a basic understanging, if it is charging , discharging, basic condition of the battery, the charging condition of the alternator/generator etc
"a milivolt meter that measures the voltage drop from the wire that goes from the connector behind the battery to the horn relay"
Which in effect only tells one the same thing as a bloody useless ammeter.
So if the factory is teconatly a voltmeter, who cares at the end of the day it is useless other than the consol cluster would stupid with only 3 gauges.
BUT...an after thought on this..If it is a volt meter, then one should be able to put a resistor or something in the curit so it reads right and connect it across the battery feed.
Ok this is out of my leauge....you bright sparks (pun intended lol) can this be done?
Steptoe is offline
post #14 of 17 (permalink) Old Jan 13th, 10, 11:02 PM
James
Re: Voltmeter
Well, the factory calls it an ammeter.
post #15 of 17 (permalink) Old Jan 15th, 10, 03:19 PM Thread Starter
Milt
Re: Voltmeter
I definitely think the volt meter is much more usefull. The hard part is explaining to the boss why I need to shell out another $120.00 on the black hole in the garage!
