250 ignition coil wiring. please help - Team Camaro Tech
post #1 of 3 (permalink) Old Jan 12th, 10, 11:55 AM Thread Starter
Unhappy 250 ignition coil wiring. please help
Hi,
I am installing a built 250 from a 74 camaro into an 87 monte carlo. Where do the tan and black wires coming from the coils pos. terminal go to?
Thanks, Mike
suprchevyshow250 is offline
post #2 of 3 (permalink) Old Jan 12th, 10, 02:04 PM Thread Starter
Question Re: 250 ignition coil wiring. please help
I know that the tan wire is 12v, but the black stiffer wire is actually in the same crimp as the yellow wire. does this lead off to a resistor?
post #3 of 3 (permalink) Old Jan 12th, 10, 05:58 PM
Jeff
yellow69RS's Avatar
Assuming a points dist not an HEI. Positive side of coil is resistored ignition feed. Also on Positive side is a bypass wire from the "R" terminal at the starter. this bypass provides a full 12 volts only when cranking. the other side of the coil (negative ) goes to the points.
Jeff
yellow69RS is online now
