High beam head lights not working - Team Camaro Tech
post #1 of 12 (permalink) Old Jan 19th, 10, 09:16 PM Thread Starter
I have a 67 that only low beams are working, dimmer switch is OK when you switch dimmer the little red light on dash comes on but no lights? Any help would be great
Sassy67 is offline
post #2 of 12 (permalink) Old Jan 20th, 10, 03:14 AM
Jess
Re: High beam head lights not working
My 67 did the same thing. It was the carpet getting caught in the dimmer switch. Little frays were caught in the button. It allowed the red light to come on but the not the headlights. Didnt matter how many times stepped on it.
Jess67
67 Camaro Blue 427, 4-speed, 12 bolt
67 Camaro 350, 200-4R, PS, AC, PB, IN PARTS
Jess67 is offline
post #3 of 12 (permalink) Old Jan 20th, 10, 10:09 AM
Could be the floor switch as well, eh?
capt
Bumper sticker- I'm not SPEEDING
I'm QUALIFYING!
captcanuck68 is offline
post #4 of 12 (permalink) Old Jan 20th, 10, 01:17 PM
Kev
Check to see if the high beam filaments are burned out with an Ohm meter, and check for 12VDC at the connector.
Then come back to the dimmer switch if there's no 12V.
67sc is offline
post #5 of 12 (permalink) Old Jan 20th, 10, 01:19 PM
It's almost always the floor switch or connection at the switch. The floor gets rusty/dirty in that area. And the switches don't cost much.
Melrose RS is offline
post #6 of 12 (permalink) Old Jan 20th, 10, 03:15 PM
prostreet69camaro's Avatar
Make sure the connector on the dimmer switch is melted and had a bad or loose connection.
prostreet69camaro is offline
post #7 of 12 (permalink) Old Jan 20th, 10, 08:30 PM Thread Starter
I did pull the carpet back and also tried new switch still did not work
Sassy67 is offline
post #8 of 12 (permalink) Old Jan 21st, 10, 07:39 PM
Kev
But are the high beams burned out and do you have voltage at their terminals?
67sc is offline
post #9 of 12 (permalink) Old Jan 22nd, 10, 08:15 PM Thread Starter
I will have to check bulbs
Sassy67 is offline
post #10 of 12 (permalink) Old Jan 22nd, 10, 08:29 PM
You just have to go through a logical progression to find the problem or problems. Using a tool like a volt meter or test light for this problem can be used to find out the problem(s).
If the low beams work and the high beam indicator light works it could be the bulbs but both quitting at the same time would be a slim chance and if I had to take a guess, I might think you lost a connection between the two halves of the bulkhead connector. I would think the indicator light is either getting power down at the floor dimmer switch or somewhere between the switch and the backside of the bulkhead connector.
SOA-Nova is offline
post #11 of 12 (permalink) Old Feb 28th, 10, 06:08 PM Thread Starter
Tt
Sassy67 is offline
post #12 of 12 (permalink) Old Mar 14th, 10, 05:19 PM Thread Starter
Found the problem the connector plug for the lighting to the firewall was not in all the way, I pushed in on it and the high beams came on, I pulled the connector off and found it had 2 prongs bent over. Straightened them out it works now but found a lot of splices, I think I going to order a new lighting harness to avoid future problems. Thanks for the help
Sassy67 is offline
