What Battery to use & method to keep batt chrgd on test stand - Team Camaro Tech
post #1 of 4 (permalink) Old Jan 20th, 10, 05:07 AM Thread Starter
Question What Battery to use & method to keep batt chrgd on test stand
What size/capacity battery to use on a factory rebuilt SBC 350? I need the battery for a test stand operation.
The engine turns by hand but is fairly tight from the factory over .040 piston/ring rebuild.
Also can I use a battery charger to keep the battery operational while running the engine on the test stand? The only load will be the standard ignition system and a 16" radiator fan that will require 12VDC-16 amps and Holley electric choke.
Thanks for all answers/advice ahead of time!
jlighthart is offline
post #2 of 4 (permalink) Old Jan 20th, 10, 06:16 AM
Re: What Battery to use & method to keep batt chrgd on test stand
Interstate MT-78DT; Yes.
post #3 of 4 (permalink) Old Jan 20th, 10, 01:31 PM
Kev
If you do some research automotive batteries, you'll find that there are only about 3 companies who make them in the US. So you can even go down to the dreaded Autozone and buy a battery and it will be a good one. Don't believe me. Do the search and read.
My philosophy is get the biggest battery that will fit in the battery box with the correct terminal orientation.
I'd think the engine and fan will run fine off just the battery for as long as you would need to run it on the test stand, but to use the charger at the same time, you need a big charger or risk toasting the charger.
Unless its a jump start type charger, I wouldn't start the engine with the charger connected.
I've had good luck lately moving a small battery tender from a big battery to the motorcycle battery every 2 weeks. Why I didn't buy two I don't know.
Just my opinions...
67sc is offline
post #4 of 4 (permalink) Old Jan 20th, 10, 02:27 PM
Originally Posted by 67sc View Post
my philosophy is get the biggest battery that will fit in the battery box with the correct terminal orientation.
x2
BPOS is offline
