Windshield Wiper Motor help - Team Camaro Tech
post #1 of 4 (permalink) Old Jan 26th, 10, 01:02 PM Thread Starter
Ryan
When i have all the wires connected i start the car and no matter what setting i have my wipers on (high, low, off) they move but only half way on the windshield. I dont know if it is wireing issues or the motor itself. Any help with this would be greatly appreciated.
rmk392 is offline
post #2 of 4 (permalink) Old Jan 26th, 10, 04:54 PM
Re: Windshield Wiper Motor help
Do they go up half way and back down or up half way and stop?
If they are going back and forth but only 1/2 way up, its probably an issue with the linkage (also called the wiper transmission)
If they are just stopping, check that the motor has a good ground.
400bird is offline
post #3 of 4 (permalink) Old Jan 26th, 10, 06:38 PM
Kevin
Disconnect the linkage and see what the motor does. If you still have the same problem check your wiring.
kcart55 is offline
post #4 of 4 (permalink) Old Jan 27th, 10, 03:48 AM
Kevin
KevinW's Avatar
The part about it being in the "off" position and the wipers go halfway is puzzling If the wipers speed is correct in high and low and it parks normally. A too short motor arm would be the issue. If it just moves half way and stops and the arm only goes 1/2 revolution then its an internal motor issue or a park circuit issue.
Some other symptoms?
Kevin
KevinW is offline
Tags
motor, windshield motor, wiper, wireing
