Back up Light switch - Team Camaro Tech
post #1 of 6 (permalink) Old Feb 1st, 10, 05:44 AM Thread Starter
I am trying to make my back up lights function, have the switch, bracket, heat shield, and all of the wiring harnesses. It would be awesome if someone could show me how the wires make it from the switch to the console. One of the harnesses says it is supposed to mount to the firewall, the question is where? (FOUND IT) Also, I have read that the rod that operates the switch (from the shifter to the switch) must be fabricated, an pics of what one looks like would be huge also. Thanks
68 RS/SS Muncie 4spd and Hurst shifter
blumarln is offline
post #2 of 6 (permalink) Old Feb 1st, 10, 01:12 PM
Darrin
dfahy68's Avatar
Re: Back up Light switch
If memory serves it's the pink/green wires coming from the harness under the dash. I routed them through the firewall grommet, along the tunnel to the backup switch. Had to splice extra wires to reach the switch. What kind of switch are you using? Mine came with the rod: http://www.summitracing.com/parts/HUU-2480003/
Join the NRA today.
dfahy68 is offline
post #3 of 6 (permalink) Old Feb 1st, 10, 03:30 PM Thread Starter
I figured out the routing of the wires, found the hole in the firewall. The issue I have now is that I have a Muncie Tranny and a Hurst Shifter, so I have the correct switch for a Muncie tranny, but the rod that operates it is incorrect. I was just wondering if anyone had a photo of the rod they are using or how they made this work. this is the switch I have: http://www.rickscamaros.com/product....dept%5Fid=3122
blumarln is offline
post #4 of 6 (permalink) Old Feb 1st, 10, 04:58 PM
Keith
Rick's has the one you need:
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
keithl1967 is offline
post #5 of 6 (permalink) Old Feb 1st, 10, 05:39 PM
Harvard
If that doesn't work, I made one for mine out of a bike spoke.
1968 Z28 British Green, all original except CE 302 engine. Have original owners booklet and protect-o-plate.
68zproject is offline
post #6 of 6 (permalink) Old Feb 1st, 10, 06:19 PM
Tony
Send a message via AIM to tony -Di
I made my wire from a wire coat hanger
tony -Di is offline
