Last wire to figure out!!! See pic. - Team Camaro Tech
post #1 of 12 (permalink) Old Feb 5th, 10, 05:49 AM Thread Starter
Brandon
I labeled all my wires and for some reason the label must have fallen off this wire. See the pic below...sorry about the quality. The wire is yellow and has a black box-shaped female connector on the end. It exits the dash wire harness at the same place as the heater control wires. I am 90% it is the radio wire, but want to make sure. Also, it has a factory metal clip attached to it.
Thanks!!!
brandonvelek is offline
post #2 of 12 (permalink) Old Feb 5th, 10, 06:47 AM
click's Avatar
Re: Last wire to figure out!!! See pic.
do you have the AIM with the wiring diagrams? I see 2 yellows, one single yellow goes to low fuel module in a console car. The radio is a yellow and black wire together in a black female plug.
You need to have the diagram so you dont use the wrong wire in the wrong place and produce a short. Also, for folks that have not seen your posts before, what car? what year? what tranny etc. wiring changes depending on alot of that info.
click is offline
post #3 of 12 (permalink) Old Feb 5th, 10, 08:06 AM
Kevin
KevinW's Avatar
That clip looks like the e-brake cable clip, but that wire has a round terminal.
Kevin
KevinW is offline
post #4 of 12 (permalink) Old Feb 5th, 10, 08:47 AM
Christropher
Brandon, update your signature or your profile w/ what model/year car you have so folks don't have to ask First name and Location fields are nice to see too bud! Thanks!
Christropher
...in pieces still.
clwilcox33 is offline
post #5 of 12 (permalink) Old Feb 5th, 10, 12:51 PM
Keith
looks like it might be the wire that runs to the glove box courtesy light (if the car was so equipped...
If you think it's the radio wire, probe it with a circuit tester, then pull the fuse for the radio and test agai...
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
keithl1967 is offline
post #6 of 12 (permalink) Old Feb 5th, 10, 01:41 PM
click's Avatar
glove box light wire is Orange... the diagram above shows all the wires in 68-69 but probably good in 67 too.
click is offline
post #7 of 12 (permalink) Old Feb 5th, 10, 01:59 PM
Jonesy's Avatar
It wouldnt go to the console, those wires are all in the main harness that plugs into the guage package.
Yellow is typically the Radio power wire.
Team Camaro Gold Member #14
1969 Camaro RS/SS L48 4 speed
Jonesy is offline
post #8 of 12 (permalink) Old Feb 5th, 10, 05:01 PM
Keith
the perils of being color-blind, I suppose...
Makes wiring lots of fun, shockingly enough
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
post #9 of 12 (permalink) Old Feb 6th, 10, 12:35 PM Thread Starter
Brandon
Sorry for the lack of info. I have a 67 RS 4spd.
Yes, I have the wiring diagrams. The proplem with the diagrams is it does not show options. I have the yellow low fuel wire already located. It is not yellow and black. It looks exactly like the low fuel wire all yellow. The wire exits the harness like it would go to the console, radio, heater controls, etc. I have all the wires to the console.
it is not the e-brake or the glove box wire.
The car originally had a rear defrost...I wonder if it is the lead to that???
post #10 of 12 (permalink) Old Feb 6th, 10, 12:47 PM
radio wire.
1969 Chevrolet Camaro 396 SS X-66
1967 Chevrolet Camaro RS Convertible
Brandan is offline
post #11 of 12 (permalink) Old Feb 6th, 10, 12:48 PM
mark
mark x22's Avatar
the 1967 wiring diagram shows a single yellow for 1967 for the radio the 1969 shows yellow and black together . do like Jonesy said and check to see if it runs to the radio fuse .
mark x22 is offline
post #12 of 12 (permalink) Old Feb 6th, 10, 01:58 PM Thread Starter
Brandon
Cool. Thanks!!!
Brandon
67 Butternut RS 4spd. Muncie w/ OD (0.87 4th)
408CI w/ 508HP/530TQ
, 12 Bolt, Hotchkis Springs, 3" Magnaflow
Wilwood Brakes, March Pulleys, Vintage Air, Foose Legends
