Signal light troubles - Team Camaro Tech
post #1 of 3 (permalink) Old Feb 6th, 10, 05:52 PM Thread Starter
i have a 67 rs/ss with a big block in it. the headlights work fine. doors open and shut no probs. the emergency flashers work. i can give a left or right signal and the light lights up but will not blink. i can hit the brake pedal and and they light up. pull the parking lights on and they work. it just doesn't work when i signal (they just sit there brighter but do not blink). i have changed the flasher on the fuse box. checked all the bulbs. rechecked all the grounds and they are good.
any ideas would be appreciated.
thanks in advance
slo72 is offline
post #2 of 3 (permalink) Old Feb 6th, 10, 05:59 PM
ZZ_430's Avatar
Re: signal light troubles
There should be another flasher under the dash near the steering column for the blinkers. The flasher on the fuse block is for the 4-ways.
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #3 of 3 (permalink) Old Feb 9th, 10, 08:03 PM Thread Starter
Re: Signal light troubles
fixed purple wire and black wire next to ignition switch.
thanks alot!!!!
slo72 is offline
