Looking for painless wiring harness/ kit for 68 camaro - Team Camaro Tech
post #1 of 11 (permalink) Old Feb 7th, 10, 06:46 PM Thread Starter
Doug
Looking for a painless wiring harness/ kit for my 68 camaro..
all the old wiring is junk.
where is a good place to buy from and is reasonable in price?? thanks
sok68camaro is offline
post #2 of 11 (permalink) Old Feb 7th, 10, 07:12 PM
67 455 Bird ragtop's Avatar
Re: looking for painless wiring harness/ kit for 68 camaro
If this is a stock rewire why would you want to use Painful??? Use either M&H or American wiring.
67 'Bird vert 455 JW TH400 KRE d-port 310 cfm heads H-beam rods Comp Cam 305-AH-8 cam w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Radials 31x18x15 on Convo Pro 15x15s
67 455 Bird ragtop is offline
post #3 of 11 (permalink) Old Feb 7th, 10, 07:35 PM
What he said. Painless is not reputed to be painless.
Mike - '68 Camaro with lots of stuff done to it.
Mkelcy is offline
post #4 of 11 (permalink) Old Feb 8th, 10, 02:59 AM
Everything on my car (including the power window harnesses) was redone (rewrapped with new connectors) or I purchased new (engine and taillight harness was shot) from M&H Electrical Fabricators. They do good work.
67 Camaro: 454/TH400/4.10 12 bolt. Lots of options: PS/PDB/PW, tilt, tach, gauges and more. K-K + 797-Z...
"Politics is the art of looking for trouble, finding it whether it exists or not, diagnosing it incorrectly and applying the wrong remedy" - Sir Ernest Benn
PowerWindows is offline
post #5 of 11 (permalink) Old Feb 8th, 10, 04:07 AM
As the others have said, you can search "painless" here and read the threads and find that a lot of folks think it is anything but painless. Have to reuse a lot of the factory connectors (think lots of splices), and the directions are not great and tech support is hit or miss. If you get their GM "specific" kit, it's around $500.
The AAW Classic Update series is the same general idea, modern blade fuse box and lots of extra circuits for electric fans, power windows and seats, engine control computer, etc. All in a much better kit, with new OE style connectors, good directions, and excellent tech support. Roughly the same price as Painless, around $500 to rewire the whole car.
Eric
Eric Kammerer is offline
post #6 of 11 (permalink) Old Feb 8th, 10, 06:25 AM
Bill
Re: Looking for painless wiring harness/ kit for 68 camaro
I used painless for my 69 total rewire and it was fine , around 500.00. You do have
to use some of your old connectors though. AAW does look like a better kit, I didn't
know about them at the time.
Phx 69 camaro is offline
post #7 of 11 (permalink) Old Feb 8th, 10, 07:53 AM
prostreet69camaro's Avatar
It also depends on if you are going to do custom wiring or factory looking wiring. I use painless all the time. They do have there issues.
If you have all factory ends and route it like factory,,AAW is the way to go. But if you route your wires under the fenders so you cant see any wiring then painless is the way to go. You will be putting your own ends on the wires because of the wire length.
prostreet69camaro is offline
post #8 of 11 (permalink) Old Feb 8th, 10, 10:05 PM
AAW update kits are the same way. Wires are EXTRA long. What is even better is AAW comes with an accessory plug so you do not have to bundle a spool of wire under the dash for options you may not be using. If you have painless issues, why not change?
Musclerodz is offline
post #9 of 11 (permalink) Old Feb 9th, 10, 01:23 PM
The only problem I had was on the light switch. They make 2 different light switches for 69 GM. One with seven wires and one with eight wires. All I had to do was move a wire for the seven wire switch. Not that big of a issue. It was for the running lights to be on when the headlight lights are on.
I will look into AAW harnesses next time.
post #10 of 11 (permalink) Old Feb 9th, 10, 02:12 PM
Dave C
One thing with AAW is customer service its a GM guy that designed it and will help in every way you need to make you happy.I called painless with no help and I think they were Indians that I was speaking with.This is what turned me off with Painless.I hope this is not bashing me saying that the customer service was Indians.This was about two years ago may be things have changed.
PRO.ST69orange
post #11 of 11 (permalink) Old Feb 9th, 10, 05:44 PM
Painless was painfull for me. Go w/ another kit. Brian
1969 original SS in family since 1971.350/330 crate w/ comp 270 roller cam,2004R,355 12 Bolt posi,P/S P/FTD Brakes P/W P/TOP Orig A/C car but removed.
Car nut is offline
