Brake light problems - Team Camaro Tech
post #1 of 3 (permalink) Old Feb 11th, 10, 09:10 AM Thread Starter
I have a67 camaro that I just put in a ez wire kit. when I hit the brakes the front parking lights also light up. I cant seem to find the problem
smokey1010 is offline
post #2 of 3 (permalink) Old Feb 11th, 10, 09:16 AM
Mickey
Moonpie's Avatar
Re: brake light problems
You will most likely have to physically trace the wire from the park lights until you find what they are connected to and se if that is where it should be or where they are shorted to the brake light switch wiring.
Moonpie is offline
post #3 of 3 (permalink) Old Feb 12th, 10, 08:37 AM
Had same problem with my 68 back in 1968. Check your tail light bulbs, if you have the wrong bulb it will cause it to short between the brake and running lights. This may not be your problem but it's worth a look.
1968 Camaro SS / 454
Driving the Dream!!!!!!!!
albrock is offline
