No power to engine harness - Team Camaro Tech
post #1 of 7 (permalink) Old Feb 11th, 10, 06:19 PM Thread Starter
Bubba
Not real sure what happened but I've lost power to all the fuses on the right side of the box. I've checked all my grounds and basic stuff i know to do , just wondering if there was a specific wire that supplies power to that side to help me narrow down my problem .Thanks
BiGBuBBa is offline
post #2 of 7 (permalink) Old Feb 11th, 10, 07:28 PM
Daryl
1968RallySport's Avatar
Re: No power to engine harness
check your fusible links
1968RallySport is offline
post #3 of 7 (permalink) Old Feb 13th, 10, 07:42 PM Thread Starter
Bubba
I was checking all my fusible links , grounds, fuses and everything else i could think of and everything seemed fine. but i was messing with the key trying to see if it would do anything and i heard my fuel pump and defrost come on when i tried to start it everything went back dead and lost power at the fuse box on the right side again does anyone know if that would be a bad ignition switch ???
BiGBuBBa is offline
post #4 of 7 (permalink) Old Feb 13th, 10, 11:28 PM Thread Starter
Bubba
Ignition Switch !!! but as always fix one thing something else happens...replaced my bulbs why i had cluster out now nothing lights up ...oh well guess i'll have something to do in the morning.
BiGBuBBa is offline
post #5 of 7 (permalink) Old Feb 14th, 10, 08:48 AM
Twist the bejesus out of the headlight knob as the rheostat might have a burnt spot on it. Also, might jiggle the headlamp connector.
post #6 of 7 (permalink) Old Feb 14th, 10, 11:13 AM Thread Starter
Bubba
twisting the knob worked ...Thanks!!!!
BiGBuBBa is offline
post #7 of 7 (permalink) Old Feb 14th, 10, 03:25 PM
Cool!
