Hi-beam light flash on/off - why ? - Team Camaro Tech
post #1 of 5 (permalink) Old Feb 12th, 10, 01:19 PM Thread Starter
Scotty
Hi Guys,
I have done a full resto on my car so everything is new. The problem I am having is I can drive around all night on low beam no problems. Once on high beam it might only take a few minutes but then both lights just start flashing on & off, put it back on low beam & they work fine again.
Spoke to an auto electrician & he said maybe in the headlight switch there is some sort of ( cant remember what he called it ) where ifthe globes are too many watts it can overload the switch. Took the globes out & it had 60w lows & 110w highs. Fitted some new Tungsram superblue low beams which are 60/55w & Osram cool blue 55w high beams which are supposed to be a lot better globe. Thought maybe these would not draw as much power through the switch. The light is now much better but still does the same thing flashing on & off.
One thing I have not replaced is the dimmer switch on the floor so am not sure if that could have something to do with it.
Has anybody had these sort of issues before or know what it could be ?
A REAL ENGINE IS AN ORANGE ENGINE !
406 SBC, AFR 195's, Comp 242/248 @ 50 hyd rol, RPM Airgap, 10.7 comp, 830 DP, 4000 stall, Turbo 400, 3.73 12 bolt posi, 383RWHP, 11.369 @ 118.71mph.
SBC-68-FIREBIRD is offline
post #2 of 5 (permalink) Old Feb 12th, 10, 01:24 PM
Jon
Re: Hi-beam light flash on/off - why ?
Headlight switches usually have a heat sensative circuit breaker. A new headlight switch would be a cheap thing to try.
Jon N
dyno jonn is offline
post #3 of 5 (permalink) Old Feb 12th, 10, 01:27 PM
BILL
SPARKY69's Avatar
dimmer switch shorting out, been there before!
BILL D.
JOHN 3:16
SEMPER FI
SPARKY69 is offline
post #4 of 5 (permalink) Old Feb 12th, 10, 05:01 PM
Some reading for ya.
http://madelectrical.com/electricalt...adlights.shtml
Youngladd is offline
post #5 of 5 (permalink) Old Feb 13th, 10, 04:52 PM Thread Starter
Scotty
Thanks for the replies guys. Will fit up a new dipper switch during the week & see how she goes !
