69 console low fuel warning indicator? - Team Camaro Tech
post #1 of 8 (permalink) Old Feb 13th, 10, 10:19 AM Thread Starter
Can someone explain how this works. In the console gauges is the LFWarning indicator canister with circut board. It also has what looks to me like a socket for a light bulb but I could have this wrong. Its all there minus a bulb. The dash idiot lights have a FUEL indicator with a bulb behind the window, although I have never seen it illuminate.
Whats the behavior of this system when its working? Is this on all 69's with factory console guages? Apreciate any help on this. Confused
69pcar is offline
post #2 of 8 (permalink) Old Feb 13th, 10, 10:25 AM
"Tri-Tip"
Gary L's Avatar
Re: 69 console low fuel warning indicator?
A light bulb is not required plugged into the module. When the fuel level gets low the dash indicator lights. The after market modules are not that great. They tend to start indicating at around 1/4 tank of fuel. It is used on all factory console w/ gauges.
Gary L is offline
post #3 of 8 (permalink) Old Feb 13th, 10, 10:35 AM Thread Starter
Meaning?.... A bulb was their, could be their? Supposed to be their? Factory their? or was never their?
69pcar is offline
post #4 of 8 (permalink) Old Feb 13th, 10, 02:54 PM
"Tri-Tip"
Gary L's Avatar
There was never a bulb.
Gary L is offline
post #5 of 8 (permalink) Old Feb 14th, 10, 08:01 AM
click's Avatar
The low fuel module was used in other Chev cars too, some of those got the bulb put in them. In Camaro, no bulb in the socket. The system uses the "fuel" light in the dash panel as the light to tell you its getting low.
I taped mine up into the back of the panel to keep it from rattling around and it works great.
click is offline
post #6 of 8 (permalink) Old Feb 16th, 10, 07:33 AM Thread Starter
Excellent, thank you.
69pcar is offline
post #7 of 8 (permalink) Old Feb 16th, 10, 01:42 PM
Brad
RS3SDL2MG's Avatar
to go into this a little deeper I went thru all this with my 67 and have put a new low fuel module on mine (HAVEN'T GOT TO DRIVE THE CAR YET FOR THE SNOW) but any way learned how these thing's work
1967 : when the fuel level get's below a 1/4 tank the module put's 12 volt + power on the YELLOW wire going to the low fuel bulb in the dash ,
1969 : when the fuel level get's below 1/4 tank the module put's a ground on the YELLOW wire
to test the bulb
1967 : put 12 volt + power on the YELLOW wire going to the dash BULB SHOULD COME ON
1969 : GROUND - the YELLOW wire going to the dash BULB SHOULD COME ON
my new reproduction module came with a sheet that read's NEVER INSTALL A BULB INTO THE LOW FUEL MODULE SOCKET
1967 RS 327
RS3SDL2MG is offline
post #8 of 8 (permalink) Old Feb 17th, 10, 03:29 AM
Brad
RS3SDL2MG's Avatar
Question Re: 69 console low fuel warning indicator?
the fact that the aftermarket low fuel modules make the light come on at about 1/4 tank was my favorite part of the new one ,
WHY WOULD THAT BE BAD ?
1967 RS 327
