Printed Circut Board Replacement - Team Camaro Tech
post #1 of 5 (permalink) Old Feb 15th, 10, 06:52 AM Thread Starter
Question Printed Circut Board Replacement
Hi Guys
Does anyone know how to replace the printed circut board for the instrument panel? The one I have in my 67 with tach appears to have a lot of burnt spots. I have a new board, but I'm not sure how the old one comes off and the new one goes on.
Any help would be greatly appreciated.
67 3L 4P Project Car
I just had to have some wings.
67 RS/SS Pictures
cpodeep is offline
post #2 of 5 (permalink) Old Feb 15th, 10, 08:54 AM
Re: Printed Circut Board Replacement
I replaced one in my corvette once and as I remember it was just held in by some push fasteners to the back of the pod. If you get the panel out I think it will be simple.
1969 Z28
1969 Firebird 400
My new project for 2010 DONE/ Sold.
2002 Camaro SS LE/SLP
67 Nova SS 327, M20, 3.73
nashcar is offline
post #3 of 5 (permalink) Old Feb 15th, 10, 09:35 AM
Larry
larryh56's Avatar
Scott, it is easy once you get the instrument housing out, it is attached with a few screws. To get the housing out you need to drop your steering column from under the dash (make sure to support it, do not let it drop farther down then you need to get the housing out). There are good posts about this. There is a ground attached to the top center screw which you should make sure is working when you put the housing back in or you are guaranteed to have troubles.
68 RS Coupe 355/350 TH, Detroit Speed, Hotchkis, Vintage Air, 8.5" 3.42 posi 10-bolt, MagnaFlow 2 1/2" exhaust, etc.
"The public cannot be too curious concerning the characters of public men."
Samuel Adams
larryh56 is offline
post #4 of 5 (permalink) Old Feb 18th, 10, 07:40 AM Thread Starter
Thanks Guys for the info!
I just wasn't sure if it was epoxied or something to the back. A project to do when and if it ever gets back from paint.
67 RS/SS Pictures
cpodeep is offline
post #5 of 5 (permalink) Old Feb 18th, 10, 10:40 AM
Darrin
dfahy68's Avatar
Scott,
One thing to look for while you're doing the circuit board - I had trouble with my dash lights not working. I thought it was the circuit board, but instead the black plastic light holders -don't know what else to call them- were corroded inside where the bulb makes contact. If you're reusing old, make sure the copper leads inside make good contact with the light bulbs. I used a small file to clean off the corrosion. Lights work great now.
Join the NRA today.
dfahy68 is offline
