Help with 67 Firebird - Team Camaro Tech
post #1 of 6 (permalink) Old Feb 15th, 10, 08:23 AM Thread Starter
Hoping someone here can help. A friend of mine is putting together a 1967 Firebird 400 with 4 speed. It is an original 4 speed car but there is no hole in the firewall where the reverse switch harness would go like on the Camaro. Does anyone know if the Firebird reverse switch harness was set up the same as the 67 Camaro. I just find it odd that there is no hole there for it when it is an original 4 speed car. Could Pontiac have brought that harness in somewhere else?
1969 Camaro SS
350/300 M20
12 Bolt 3:73 Posi
Myfirst 69SS is offline
post #2 of 6 (permalink) Old Feb 15th, 10, 09:27 AM
Brandon
Re: Help with 67 Firebird
Is there not a two prong plug on the firewall just behind the dizzy?
Brandon J. licence 1NASTY67
Nantooch is offline
post #3 of 6 (permalink) Old Feb 15th, 10, 10:09 AM Thread Starter
Here is a pic of the reverse harness on a 67 Camaro. Would the 67 Pontiac Firebird be in the same location with the same harness?
1969 Camaro SS
350/300 M20
12 Bolt 3:73 Posi
post #4 of 6 (permalink) Old Feb 16th, 10, 12:15 PM Thread Starter
Anyone?
1969 Camaro SS
350/300 M20
12 Bolt 3:73 Posi
post #5 of 6 (permalink) Old Feb 16th, 10, 12:33 PM
67 455 Bird ragtop's Avatar
Originally Posted by Myfirst 69SS View Post
Anyone?
I left a post for you over on the first gen firebird site. SOmeone there may have the answer for you before I can get home and look at my manuals. My 'Bird was originaly a two speed car and the harness connected to the shifter. They may have done something similar with the 4-speeds.
67 'Bird vert 455 JW TH400 KRE d-port 310 cfm heads H-beam rods Comp Cam 305-AH-8 cam w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Radials 31x18x15 on Convo Pro 15x15s
67 455 Bird ragtop is offline
post #6 of 6 (permalink) Old Feb 17th, 10, 02:28 PM
Yes it is the same design as the camaro .I have a 67 FB with the 400 4 speed also, my buddys 67 rs/ss is in my shop and they are in the same place.
fmfire672 is offline
