Orignal 69 tach with HEI, will it burnout - Team Camaro Tech
post #1 of 10 (permalink) Old Feb 15th, 10, 03:54 PM Thread Starter
Jake
Hello people
I have a 69 camaro original oer actually. I read it would not work with a hei. Hope someone can help with will it work and hook up.
THANKS JAKE
Jake 69 is offline
post #2 of 10 (permalink) Old Feb 15th, 10, 05:14 PM
Banned
Alan
98blackburb's Avatar
Re: Orignal 69 tach with hei will it burnout
I have a 1969 SS with factory tach, I plugged in my HEI and it's working for mine.Ask around,just telling you my story.
98blackburb is offline
post #3 of 10 (permalink) Old Feb 15th, 10, 05:26 PM
madmax87's Avatar
The OER works fine with HEI. I have them installed in 2 of my 69's. I've been told that you do not want to use the originals with HEI.
madmax87 is offline
post #4 of 10 (permalink) Old Feb 15th, 10, 05:41 PM Thread Starter
Jake
Thanks Dennis I seen somewhere that it didn't work. but if yours is good i will try. Didn,t
want to ruin it. How do you like autogear trans? I am thinking about a M22W. where did
you get yours?
Jake 69 is offline
post #5 of 10 (permalink) Old Feb 16th, 10, 05:08 PM
Re: Orignal 69 tach with HEI, will it burnout
They can burn out. In particular there is a diode and a special transistor inside called a UJT. Back in the day, semiconductors had relatively low specs on peak voltage and current. A tach filter is a good idea to help reduce the amplitude of the signal from an HEI or solid state ignition. However, there are plenty of folks who have done nothing and had no problems. IMHO, better safe than sorry - I recommend a filter.
dnult is offline
post #6 of 10 (permalink) Old Feb 16th, 10, 06:08 PM Thread Starter
Jake
thanks for the replies. Not sure i know what filter is. I will have to check
into that. Paid close to 200 for it don't want it to burn out.
THANKS TO ALL
Jake 69 is offline
post #7 of 10 (permalink) Old Feb 16th, 10, 07:48 PM
I have used a HEI on mine also. over 10 years with no problems.
TTFN
Mat
SSCARGO
Mat Klemp is offline
post #8 of 10 (permalink) Old Feb 17th, 10, 07:15 PM
DT
Donny
DT's Avatar
Forgive me OER??????
DT is offline
post #9 of 10 (permalink) Old Feb 17th, 10, 08:33 PM
http://www.jimragtop.com/tc/tachfilter
post #10 of 10 (permalink) Old Feb 27th, 10, 07:40 AM
madmax87's Avatar
you get yours?
That thing is awesome. It is so smooth and sounds great. I had a M21 before but always wanted a M22. Here is the link to where I got mine. Couldn't be happier with the service.
http://tbtrans.com/muncie_4_speed.htm
madmax87 is offline
